Inlaws are over 1000km away. Have friends nearby but haven’t mentioned it yet
Fair enough :) First week back at work , Busy with works already :(
Kieran , ill Give You a Call sometimes this week to arrange the car drop. Im struggling with time management this week [emoji24][emoji24]
Kieran , ill Give You a Call sometimes this week to arrange the car drop. Im struggling with time management this week emoji24.pngemoji24.png
Il come to ur house and do it if its easyer?
  • Like 1
2 hours ago, shoey85 said:
Morning sweet cheeks! My new pads arrived today emoji1303.pngemoji1319.pngemoji2.png
maxi or regular?
In other news, woke up this morning, rolled over to face The Good Wife who, while still sound assleep. said to me very clearly
"If you try and replace me as your wife again, I will definately kill you"
:unsure:
  • Like 3
  • Confused 1
1 hour ago, Stinky Rooster said:
maxi or regular?
:unsure:
in which u replied " not to replace, i just want 2 for when the main one is broken or out of service for a week"
yeeeeeeeeah I kinda like my genitals in-situ kthnx
besides, you would have to be absofknlutely tapped in the head to want more than 1 wife
like, mormon stylez tapped in the head
and nobody wants to go that far
  • Like 1
6 hours ago, Stinky Rooster said:
besides, you uld have to be absofknlutely tapped in the head to want more than 1 wife
Your bang on there!
Sanae once asked me what i would do if something happened to her...would i re-marry etc
i said FARK THAT!! ill be able to go fishing whenever i want without getting hassled. why would i give that up twice in my life?
  • Like 2
Your bang on there!
I’m with you ! Not about fishing tho , something else [emoji28]
  • Like 1
Louis Vuitton? Haha
Hahahaha nah ! Not a big fan .
Just watched MCM Trip to Suzuka , they bought Nissan Fairlady Z ( early 70’s) model
And took them to the race track [emoji28] $50 per hour to hire the track , wonder how much they pay that car in Japan , in here perth selling for $55k and above !
  • Like 1
well, that was a bit of a shit start to the day - stuck in a lift for over an hour.
On the upside, was stuck in there with an ex Sarich engineer, and am now fully up to spec on the history of the Orbital Engine Co., and what a fkn story!!
  • Like 2
So you know why they got shutdown then?
apparently when they changed out to the injection system for 2 strokes (from the orbital engine program) they ran in to massive issues of deposits on the injectors, caused mostly by fuel and oil purity issues, and Ford Cologne (who had been backing them until that point) pulled the plug. The company tried to go out on its own, and even produced 85 ford festivas with the system fitted, which they basically gave away on the agreement they got them back to assess after a given time, but due to the completely nonexistent support for the company, the ideas or even the chance for a full manufacturing setup here in Perth
(Tickford actually DID build a production line in Balcatta that built the first 85 cars)
It died a sad death, killed off by apathy, lack of foresight and a shit government that missed a golden opportunity to put Australia at the forefront of automotive engineering for decades to come. And if anyone thinks it was a unacheivable pipe dream, just remember that this country is full of people who have massively changed the automotive game. Blokes like Rod Hatfield, and Jim Read to name a few.
And now I am depressed and angry at mah counrty :(
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
