apparently when they changed out to the injection system for 2 strokes (from the orbital engine program) they ran in to massive issues of deposits on the injectors, caused mostly by fuel and oil purity issues, and Ford Cologne (who had been backing them until that point) pulled the plug. The company tried to go out on its own, and even produced 85 ford festivas with the system fitted, which they basically gave away on the agreement they got them back to assess after a given time, but due to the completely nonexistent support for the company, the ideas or even the chance for a full manufacturing setup here in Perth
(Tickford actually DID build a production line in Balcatta that built the first 85 cars)
It died a sad death, killed off by apathy, lack of foresight and a shit government that missed a golden opportunity to put Australia at the forefront of automotive engineering for decades to come. And if anyone thinks it was a unacheivable pipe dream, just remember that this country is full of people who have massively changed the automotive game. Blokes like Rod Hatfield, and Jim Read to name a few.
And now I am depressed and angry at mah counrty [emoji20]
The Western Australian rotary. Shame it never got off the ground. I used to work in sarich court Osborne Park. Just got back from my mates funeral. :-( huge procession of Harley and triumph bikes. Less patches. The funeral company had to get a Ford hearse from Northam because he refused to be buried in a Holden. Tought me Ali polishing, welding, bending, burnouts, bourbons, beer, strippers and the full gamet of a honest man's debauchery. Skyline was a hairdresser's car. 351 Xc 302 XD bombed 2ltr escort could never catch his Xb coupe during my apprenticeship. Bombed 351 cleavland, predator carb, manualised c10, 3500 stall, 3:95 9". Have been bursting into tears over and over from the good times we had. Got into a police chase leaving a party doing a full burnout. Lost the police in cannington rolled into his parents place with police hiding out the front and back rolled in and shut the coupe down. Lost license for 4 years. Animal. There goes my family protection plan. RIP LES.
  • Like 1
Hey gais. I’m not too bad. Been busy busy being away and also with work. Business is shit in January, people seem to have spent all they moolay over Christmas haha!!
Do come for Australia Day!! Will try get the menu for ya’ll ASAP. Elsie~~ remind me :P
  • Like 2
Do come for Australia Day!! Will try get the menu for ya’ll ASAP. Elsie~~ remind me [emoji14]
Kieran’s in the house , he’s fast and he knows what to do - [emoji8]
  • Like 2
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
