50 minutes ago, turboedsloth said:
As are the black fresh water lobsters
are you coming on to me? because its working....
keen AF to get my hands on marron or crabs, due to not being able to hunt this season :(
I can put some in the freezer for you in if want? we are also going up Perth way on a sunday in the next 2 weeks apparently.
Went out last night, was murky as all buggery. Waiting for this rain to farkkk off before i go out again
  • Like 1
ken oath I would!!!! Also keen to catch up if you are coming up. Sunday WT lunch maybe?
I has a recipe for chilli lime and coriander crabcakes that brings all da boyz to mah yard.
42 minutes ago, turboedsloth said:
Sounds like a date.
I can't do crabs. But marron, hhhhhhhhhnnnnnnnnnnggggggggggggggggggg
ooooh jeebuz. You turn up here with marron I cant guarantee I wont wrap my legs around your face. Its literally been years :blush:
Hahahahahahahahah [emoji23] sounds like me & Dave ! We both bad with phones , gotta stop that tho
I usually only check the weather and Sau once or twice a day on holidays.
Delete Facebook, and you will thank me in a month when you realize how much spare time you have
  • Like 1
I can’t really delete Facebook, photos and business page all there [emoji24][emoji24]
Sunburn- sunscreen
Best sleep ever in our van...the beers prob help
Dirt- sometimes depending on location
Food- wife cooks as well camping as at home but menu choices are reduced
Scenery- sensational
thats some pretty flash welding there dude. Reckon I might hit you up soon for a foreigner [emoji14]
Thanks dale. MIG Welding is just welding, once the geometric pattern development is done I've already lost interest. Parallel, radial line and triangulation is the fun part for me :-) we finally have a bender arriving soon so. Exhaust manifold off, machined, sand blasted and painted with all new studs. Dual cai's, Ali coolant/dual motor washer bottle, pod filter box. Got bad hot air stacking under the bonnet. Would like to do Ali but might be stainless. Due to free bits from work. You know on top of the 50hrs I put in this week. Haven't used the turbo timer because intercooler but you can hear the manifold pinging under cool down. Don't want to go with lagging or blankets because it traps the heat in bad? Any thoughts?
Marc at C-Red reckon timers are pointless unless your racing, turbo blanket could be cool!
  • Like 1
Yeah my bro reconds the same. Switch it off while it's hot so the oil feed maintains pressure around the bearings. Dave said use it for now on Cool down because the manifold is warped and ticks bad for ages on cool down. Won't matter when it's fixed I suppose. Turbo/manifold blankets/lagging are a trade off because they hold the heat in which makes for less exhaust efficiency due to increased exhaust/turbo temps. Will do dual cai's. One to the original air box position, with the back open towards the turbo and one across the front of the engine toward the exhaust manifold through the hole that isnt used from front facing plenum. Will put heat shielding guards over the manifold and turbo that will hopefully keep the heat down to be blown out by cai's to avoid the stacking issue?
Have an industrial precision EGT sensor In my Ute. it drops from 350C to 160-180 in 20 seconds or so of idle or decel. Giving it another 2 minutes of idle time only gets it down to 150C so why bother.
Just back off for the last few seconds of driving and shut it straight down. Not being under load at the end the turbo will stop spinning relatively quick and thermal siphoning will help keep turbo coolish anyway.
Turbo timers are made to piss off the neighbours.
  • Like 2
I had a timer on the stagea, never actually used it for pretty much the reasons stated,
Also, I dont think heat retaining is an issue in turbos etc. its more the moisture the lagging traps, and how that leads to massive corrosion. Seen blokes do this to motorbike exhausts and they go paper thin within a year.
  • Like 1
most likely too busy chatting up 2nd hand military equipment dealers to bother with the likes of us
or, too busy trying to keep his dog from drowning itself at every chance. Seriously, it wouldnt even drink from my dogs bowl, unless BOTH front feet were inside the water dish - and my dog has a 40lt water dish....
  • Like 1
I had a timer on my old car, was built into the alarm. My car ticked and cracked once it had shit down, i thought it haf something todo with the fact the turbo and mani were cast, the downpipe was stainless and nuts and bolts were mild
  • Like 1
oh lawd
turns out "bring your kids to work day" doesn't really work when you are counting on engineers telling them what they do, to be enough entertainment and stimulation for kids. My normally quiet office currently sounds like a day care centre that has been accidentally hosed down with red cordial and dexxies.....
damn breeders.......
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
