This snorkel template is shite. I don’t wanna drill the guard haha
Is it round? Masking tape the paint. Put the 1/4" hole through first before the holesaw so it doesn't grab and pull on the thin metal. A 1/4" shaft in the holesaw will be better than a drill to stop wandering. Hold the drill at the required angle, high pressure low revs. trefolex rtd or any lube. Whalla. Quality holesaw and arbour a must.
morning kunce!!!
So, today is the 20th wedding anniversary (insert joke here about less time served if I had murdered instead of married etc)
apparently 20th is China, so the decision is, intercooler or pit bike?
Congrats dale, we hit the 20th this year, f'ing long time mate. By chance availability and what not I married the wife on her birthday. 1 gift to rule them all. Never forget because my mum msgs me All birthdays a week before;-) show us your mum;-)
U can still get them cheap if ur willing to buy a bit of a dog. I look at around 10 cars befor i brought my last one. Im in no rush so il do the same again till i find a yellow one
Fyp brah
Came with a hole saw. Ran a 1/4 pilot them bam!
Drilled through the template slowly then added more pressure as it went through metal. Paint all good right up to the edge
  • Like 1
This thread appears to get the most WA Traffic
anyone selling some 275 / 40 / 17 drag radials in WA, prefer Mickey Thompson ETs
also after a set of 33 GTR rims, or any legit jap rams in 17x9 +20 or so
Cheers,
Awesomeness, I remember as a apprentice drilling though 80 series land cruiser Sahara's for the snorkel. Was earning 20grand a year cruiser was worth 80 grand. :-o
Cheers,
jeez some people, treating this place like a car forum :rolleyes:
sorry bro, no help here.
Cheers,
I havent got what ur after but i am curious about what ur gonna be doing with said items? Whoop ass, fast fridays or full weekend racing?
Just whoop ass Wednesday mate,
I don't live in Australia, however I am back for a few weeks shortly so wanted to give it a nudge on radials.
Have had josh at Galvsport doing some testing while i am OS.
So plan is to do a pass on the AD08s to match Josh's time
Racewars
then bolt radials on to see how we go.
Result from Josh's testing below
https://www.youtube.com/watch?v=4FWvx1LB5Bs
  • Like 1
We went away last week and the fridge in our van held food for 3 days plus a bottle of champagne and 40 beers.
Should be big enough I reckon
Trying to plan a shake down 2 night stay thinking Collie end of March and take the pups got any hidden spots I should know about?
Glen Mervyn dam, Minninup pool (and sandy bay right next door)
Mebbe even head out towards the power station and take a look at Stockton Lake?
However -  there is a track running from the highway (before the cemetry..) near the biblimum track called "Collie Scenic Drive" that takes you along the river towards the back of Collie towards minninup pool etc, and it has a crapload of perfect little camping/marroning/swimming spots. Dunno why its not better signposted, just watch out for dudes on dirt bikes :)
https://www.google.com.au/maps/place/33°20'39.8"S+116°06'28.6"E/@-33.3443981,116.1069967,419m/data=!3m2!1e3!4b1!4m6!3m5!1s0x0:0x0!7e2!8m2!3d-33.3444005!4d116.1079296
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
