happy friday bitches!!!!
the relatively stress free existence of a lowly truck driver is looking pretty fricken attractive right now :(
Fluffy - when you going to come and measure up the zorst on Ragnar for me? Got an epic new muffler on the wish list, but need a connecting pipe made up, and a couple of mounting brackets welded to the frame and muffler. You interested?
Not really that interested. I'm not a big fan of foreigners or spending any more time at work than absolutely necessary. Will be happy to have a look and sort out bends etc at cost. If you could get most of it marked out or tacked etc I'll be happy to weld it.:-) Going to see a man about another job this week. Fluffy?
Put a good word in for me
We can hang out in the lolly aisle and check the merchandise
The kit-kat club. Loads of Big'uns in the lolly aisle. We have pallets of those out the back ma'am.:'(
  • Like 1
Drove a 2500hp remote control bulldozer today.
I made the earth my bitch!!
Awesomeness, new job interview is building, fitting, hydraulics and electrical on cranes. Sounds good but they will have to beat a free ute and money first. Worth a look.
  • Like 1
Can always say no, or make demands:)
Be like tom cruise in cocktail, stuff getting thrown around
Pete, go long!!
Should work well, I'm about as old as Bryan Brown and you just need to loose about a foot and and half to measure up to Tom Cruise.
Say no more.
Had a good chat to the Minister on the weekend, we agreed the best thing to do is hand it off to a pro builder as the frame mod list id getting pretty long. Just got to find a bloke I like and trust now.
Also, used my local "hire a hoist" place to do the service on the ministers focarse too, due to me still being a creaky old bastard, and for the $60 it cost me was an absolute bargain I reckon. All I bought with me was the car and parts, everything else was supplied, so would def recommend
https://www.facebook.com/UFIXITGARAGEWA/
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
