Be like tom cruise in cocktail, stuff getting thrown around
Pete, go long!!
Just finished a full twin system on a mack truck. Turbo to y-piece dual 5" mufflers and 6" stacks. 6cyl dohc with massive turbo. At least they got the engine right ;-) can you toss a bourbon about 300kms? [emoji23]
Say no more.
Had a good chat to the Minister on the weekend, we agreed the best thing to do is hand it off to a pro builder as the frame mod list id getting pretty long. Just got to find a bloke I like and trust now.
Also, used my local "hire a hoist" place to do the service on the ministers focarse too, due to me still being a creaky old bastard, and for the $60 it cost me was an absolute bargain I reckon. All I bought with me was the car and parts, everything else was supplied, so would def recommend
https://www.facebook.com/UFIXITGARAGEWA/
The only forienger I like is. Hot blooded, I wanna know what love is, cold as ice, feels like the first time Etc. The softest metal ever made.
Actually I’m back into guitar. Maybe someday I’ll get a banjo
Hows the boy going with the classical? Be very very careful not to snap the banjo string. Would require a delicate operation and embarrassing explanation:-o
https://australindautomatics.com.au/
because spank bank
Vehicle-Inspections-508x315-8364.jpg&key=61a0776469e92e4b016a4bfecff4f4d3d91ce0aebe332ab173af05f8b9c874d9
The beard of a top quality tradesman. Years of experience glistening from the red bristles. Now there is a man you can trust:-)
Chicken coop construction coming along nicely.
Hopefully buy some Chooks tomorrow
Boc boc boc boc boc bopbgurk boc bgarg. "so I laid an egg" you should get yourself a Stinky Rooster to keep the chicks in line.
my name at work is "greybeard" and i kinda like it :blush:
Picked up a rolling frame from a TTR600 Belgrade last night for a song. Came with a beefy 51mm cartridge fork style front end and fully adjustable Olins rear shock, so suspension for Ragnar is almost sorted :woot: Just gotta get the fork emulators sorted and the changeover can begin.
  • Like 1
Successfully got kids up n fed,dressed etc this morning and made lunches for school. Got to school and car park was empty.
Oh bugger it’s only 7:20 kids. Let’s go home for an hour
  • Like 1
Gs effort!!
Parenting level - dad.
So organised you were a whole hour ahead of schedule.
  • Like 1
1 hour ago, t_revz said:
Morning babes
Sup for the weekend?
pulling Ragnar down to the frame at the front end (most of this is already done as i found a couple of spots of surface rust along the oil tank seams when I took the tank off) and pulling the front end off the new parts bike so I can make some drawings up of the new centre spindle Imma going to need to bring the 2 together, so I can get it trailered off next week to get the new tank fitted and a new seat base made.
  • Like 1
Hey babes,
Going to Harvey/Brunswick scouting camping spots and 4x4ing!!
What’s you up to?
Still got sick wife so life is hell. Worse than sick toddler ?
Got a tree getting cut down as too close to shed for me to risk. Also need to buy chooks... gumtree ppl not getting back to me :(
  • Like 1
Hey babes,
What’s you up to?
Finished the floor boards and skirting boards. Looks trick. How did the rest of the cruise go Martin?
Got a tree getting cut down as too close to shed for me to risk. Also need to buy chooks... gumtree ppl not getting back to me [emoji20]
What's for dinner dad? Squid, chicken and egg salad:-o Dead fresh.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
