Paging Trev to WT
Need a translation before I add this to the collection plzkthnxbai
Maybe you could ask sanae how vaccume docking station would be spelt, then by the magic of photoshop you could still live the dream?
Who would have thought a bike muffler wouldn't result in a sporty sounding bobcat? It seemed like such a foregone conclusion.
Yeah I would have thought it would sound cool. Length to internal diameter ratio on straight through absorption mufflers. The longer and thicker the absorption material Is the more high end frequency it will remove. We normally use 1/4" or 1/8" holes perforated sheet with a s/s mesh to stop it blowing the packing out. Can get you a magnaflow at cost if you want. The louder the better on bobcat:-) just enough to impede the headphones and spiders.
Friend had a SSS pulsar with a u13 bluebird engine (fwd sr20det) in it back in the mid 2000s, it would pull on tuned ls1 commodores of the day.
Never underestimate a Nissan with 3 s's dads mate bought a bluebird SSS years ago. The engine went hard for a n/a 4pot.
Nah mate, I'll just pick up the wheel tomorrow (I worked the last 5 days and couldn't anyway)
Yeah mate. Damn work is crazy atm. We finally got our new bender sorted. Or I bloody did. Want to make Nissan bits but exhausted. Someday :-)
She'll do it for you. Go the yellow beast.
Fired straight up. Changed oil n filter, scraped an inch of dust off the front window then drove it to the car wash for a birthday
spider webs hanging on
  • Like 1
The hydraulics are engine noise are loud so the exhaust is now inaudible.
I’m just happy it’s blowing away from me so I don’t get smoked out driving it
  • Like 1
Broom broom moar power. Moar noise. Shifting the earth again. Animal :-)
Yes, it’s all awesome my bro and I used to do 2 x 100km loops every weekend there, so much fun!!
Haha The Shoeys just being animals behind the bars or wheels for fun every weekend. Awesomeness ;-)
  • Like 1
orly?
You have my attention. Been sidetracked with the new front end, forgot I still need a zorst
  • Like 1
Bit of fuel past the rings is bugger all. She loves you and can't understand why you pulled the methanol injection and put it on a diesel ute. Probably just jealous. You know what Japanese Girls are like. Low km's one owner. Don't you dare cross me>:)
orly?
Yeah dale I can get the magnaflows at cost no probs from super cat converters in Wangara. Is a quality product I put them on my skyline and sounds good.
I put these 3" magnaflows on the Nissan exhaust when I built it. What diameter would ragnor need? [emoji23] DSC_0217.JPGDSC_0182_1.JPGDSC_0216.JPG
well, the std pipe is a fkn wierd bit of kit with a massive traingular box section hanging off the back of the muffler - there to keep it flat at the back for the pillion I assume, but that is no longer an issue, so
I am thinking about 350-400mm in length, need to have an inlet to take 1 3/4' pipe. Gotta have a nice thick casing, as its going to have lugs welded direct to the case
orly?
This is s 2 1/2" we put on little yanmars at work. If you get on the magnaflow website and get the part no. You want. No probs. DSC_0122_3.JPG
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
