Here are some pics. . .
You should really see the video of my reaction when I first saw the car =D
Bought some ze40's  Got a weird size though. . . 17x8.5 +30 i think. . .
Then after getting Anonymouse  post bought a spare set of SSR type C (I reckon they fkn hot. . .)
18x9.5+15. Bought in Japan.. they gay gold colour will get them blasted painted probably gun metal + new stickers. .
Spent nights and nights researching wheels. . mainly weights. . these 2 are super light weight.
There is lighter but they dont look as sick as these. . Buddy club almost impossible to find. . Oz racing wanted some stupid price like $3,800 for the last set in aus. pfft. .  just got Rays ze's
Burning the credit card on car gear lol. all part of the fun..
Still havent taken it for a (proper) drive yet. . . =/ only to get paper work for licence application.
So its not really driving. .  no plates on the car so felt like a criminal. . and now i have the plates so..
Just need to chop or bend them to fit though.
  • Like 3
Umm. . . Been thinking about it. . . not sure. . need to look into it more. .
Its all personal preference. . Think id feel little weird with custom. want to remain random. . like not stand out. . might change my mind. . .
eg. know a guy with a supra who took to speedway. Reckons he did under 10sec. (whether this is true doesn't really matter)
Supposedly because the car is that fast cant bring it back unless he has a roll cage. .(i don't know if this is all true).
But he had custom plates and reckons he gets pulled over alot. . . .
  • Like 1
I'm 10 min from the Perth city.
If i'm invited ill come. Keen as mustard =D
Think will be easier small cruise. last one of 40+ ppl would be little off putting. (not easy to manage)
But yeah, just catch up with cars have chat. if all things go well have a meal or drive or what-ever. =D
  • Like 2
5acb5aed4803b_volkracingze40mattebluegunmetal1.jpg.05f45fdf86d7b14d1799fc71a62ee74d.jpg
Wow dude she's a beast. Scaring v8's and cosworths Australia wide. Vspec2. [emoji41][emoji122]. Godzilla. We've got a zookey here somewhere?
  • Like 2
Of course you are [emoji28] cool
I’ll ask around and will update you all soon x
  • Like 2
Yeah they need to bend like 20mm each end to fit in front bumber. . stupidly large Aus plates =/
Either cut or bend. . dont know what cops would think. . . . but considering only been pulled over once in 15 years driving. . .
this is different car though =/
been looking at custom plates but NFI what to get. . . blegh gonna sit on fence for this one.
Bend them. Never cut plates as you can always unbend them if you need to, if they are cut you have to fork out for replacement plates if you get done for it.
  • Like 2
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
