Back in my day kids were so much tougher. We took debilitating neck injuries as a sign of manhood, dammit!
Speaking of which, sitting in my west end office about 10am this morning, and hear a godalmighty crash. Like, a building falling over, kind of sound.
The office goes dead quiet for half a second, then one of the engineers mutters "another idiot truckie just drove into the freeway overpass..."
Got it in one, tiger.
Moral of the story - almost 3 hours later the freeway is blocked solid in both directions. Enjoy your day on the road, plebs :D
Oh hey there sweet cheeks
Its been a weird week
Got a 4K tv and a root canal within days of each other
I have never been so happy and angry at the same time
48 minutes ago, t_revz said:
What size teli?
just 49' because I have a small lounge and have to sit pretty damn close.
but then I kinda HAD to upgrade the Netflix and hoooooooooly snapping duckshit batman.
Dat nbn be some good shit
We are getting disconnected in November. Need to switch to nbn. Telstra can go suck a big fat one!! Might go TPG. Other recommendations?
I have been with westnet since Jesus played fullback for Jerusalem, so it was easiest for me to stay there. Their 5G wireless router is tits, , and the fact that their call centre is in ossie park has always been a big drawcard for me.
It was actually cheaper for me on the nbn, and even with a lower end plan I can still stream Netflix in 4k with 0 issues, and that's good enough for me.
49 feet? That's a cinema m8.
Morning you beautiful human!
How are we all?
I’m just winding down the clock about 6 or so months to go unless I find alternate employment before then.
Still dole bludging?
Sell your body for moniez!
  • Like 1
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
