On 12/20/2018 at 8:19 AM, Beyond Blue R33 said:
Where are you working now Dale?
A looooong way from the CBD....
Back in the on site designing game on the Kwinana strip.  Just follow your nose to the biggest stink.
Also,  happy date related festivities to everyone,  and I hope you all kept in mind the true meaning of this time of year
https://goo.gl/images/AN6YXB
Merry Xmas fam! New mcm special out today turbos and temples 2! Get after it [emoji6]
Yeah thanks Martin I watched parts 1 + 2 last night. Would love to go for a spin on the Hakone Skyline toll road. Even in a honker. Can see where you get the inspiration for your you tube stuff from, high quality video's and presentation.
  • Like 1
How did you manage to get a job in my undies. It's low paid dirty hot sweaty work. Hope you brought the micrometer.
lulz you make it sound like I am back on the tools
not gonna happen brah
I am the annoying git in the extra-shiny-hardly-ever-leaves-the-office hi vis carrying a clipboard and a tape measure.
Are you the one telling the site workers they must wear long sleeve shirts and pants in the middle of summer outside while you sit in an air-conditioned room in your shorts and tshirt?
  • Like 1
shit no.
This place doesnt even use hi vis clothing (but the contractor I work for does - he likes us to stand out like balls on a drovers dog)
But you would have to be tapped in the head to want to walk around a refinery in t shirt and shorts. Pretty much every single thing in this place will kill you on contact.
shit no.
Sounds like the nickel refinery?
2 hours ago, t_revz said:
And lack of nasal sensitivity
Like most problems in life, the answer to this, is coffee!
Srsly, its why they put bowls of coffee beans on perfume counters in stores. If your nose stops working properly, have a big sniff of some coffee beans, and it will wake right up again.
Unfortunately, this is not recommended here. Losing smell at work is a good thing.
The burgers at the canteen are pretty tits though.
also YAY FKN FRIDAY!!!
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
