Like most problems in life, the answer to this, is coffee!
Srsly, its why they put bowls of coffee beans on perfume counters in stores. If your nose stops working properly, have a big sniff of some coffee beans, and it will wake right up again.
Unfortunately, this is not recommended here. Losing smell at work is a good thing.
The burgers at the canteen are pretty tits though.
also YAY FKN FRIDAY!!!
Yeah Friday. I finished at 2:00pm and finally have a Saturday off[emoji28]. Used a full 15kg of mig wire in 4 days.[emoji26]mms_20190109_191709.jpeg
  • Like 1
Bitchezz... what’s a cracker nursery in Perth that might have hard to find seeds? After a type of mint from japan which is permitted here but can’t find a stockist yet and eBay sellers won’t post to WA or TAS
Trev - I am a big fan of guilford nursery.  They do heaps of edibles and have an awesome staff that know everything.  They also do pretty good blueberries.
Corey  - at Kwinana but apparently I will be gracing pinjarra from time to time.
Tried them first dale as I’m a regular there but no response yet. Might get them sent to sister in Darwin then she can send to me sneaky sneaky
good luck with it bro. I know the pain of getting seeds to WA.
Last time I drove through the WA border, the guys on the front line were way more interested in the apple in the cab, than they were about the 15kg of smack in the back of the truck :D
  • Like 1
holy shitballs the roads in this city are treacherous this morning. Take care out there people!
Hit a load of dropped detergent on the way to work. Had a (thankfully very switched on driver) watch me slide completely past the bonnet of his car this morning, trying to make a turn, road turns to polished glass and all of a sudden I am going straight, despite almost full lock on the bars and about 25 deg lean. Pretty sure they heard my arse clap shut in Bunbury. NFI how I managed to stay upright and miss the car waiting to turn, but I am pretty sure it looked cool AF so that was nice....
Lol did it though it did it look more like a giraffe learning to walk [emoji6]
total crossed up speedway slide with me on top of Ragnar The Yamaha?
Nah, it looked cool. How could it not?
The scene inside my helmet/pants? Probably not so much.
  • Like 1
I was wondering what that Boom was...
Sounds like we had an opposite experience.
Took 3 laxatives in succession yesterday for surgery today. My ass blew open in the arvo and didn’t get a rest til 1am
  • Sad 1
sounds like a good time was had by all!!
Hope the slice and dice session with the vet isnt for anything srs.
If they have any left over bits, hook a brother up?
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
