Good plan right there. 25's respond to minimal mods half the time, quality high mount/manifold/gate/exhaust/injectors/ECU. Got one down here putting out 600hp with standards internals bar head gasket and cams
Ever heard of Evanco Mechanical?
My End Goal is 500hp. I don't want/need more than that. (We always say that right?), but that is a long term goal.
I forgot to mention the car has a ridiculous exhaust system (can fit my foot inside the tip ;) )
Oh, here is a photo of the freshly washed R33 4 Door, nearly ready to get some plates slapped onto her. (not embedding because the photo is huge)
Theres so much bird poo burn on her, as well as weird stains that I just couldn't remove and some weird blue-tacky glue stuff that's somehow leaked onto her. My current tools were not able to remove those.
Restorefx in Bibra lake does some pretty awesome work on car paint. Check them out. Edited by colin.ssc
I already have a motor that makes a lazy 510hp, wanna buy it off me?
  • Like 1
*WRECKING* new stock, sr20det 180sx
Mandurah, Western Australia
New stock in.
Sr20det, manual, runs and drives, video of engine running/starting is available, comp test will be performed tomorow, and 180sx will be dismantled as of tomorow.
*Notes*
Coilovers seam unservicable/seized, JIC fully adjustable fronts, rears are GAB shocks and springs, non height adjustable, with adjustable dampers.
Has good clutch, think extreme of some description. Nice feel and grab on operation.
5 speed box is good. No crunches or grinds. Smooth operation.
Engine runs/starts fine. No excessive blow by or smoke. Looks to have T25 garette.
Has VLSD and drift pineapples on the subframe.
Greddy turbo timer, blitz BOV.
has majority of rear plastics and carpet side trims, dash mat ect, steering wheel in decent condition if anyones chasing stock gear.
Only 3 rims as one is egged, 17x7 lenso.
Engine (depending on comp) complete $1200
Sr20det wiring loom $100
Turbo manual ecu $100
5 speed box $300
Clutch $200
Very fkn tempting
  • Like 1
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
