they said they're going to need another day with the car, I asked then if they could give me a progress report on the car, and they told me They've Replaced the Tint on the Rear window, and replace the springs in the front (it was too low at the front). I'm not an expert and I have no idea how busy these guys are, but they've had the car since Midday Tuesday and all they've done is put a layer of tint on the rear window and swap the springs. They told me they are currently working on the tachometer now, but the car won't be ready until end of day tomorrow.
Doesn't look like I'm bringing it to the cruise.
Hi do you guys know what process is to register a interstate vehicle in WA, have any of you done it ? Is it hard ?
I did search registering interstate but only found eastern state stuff.
Think you need to go pits , and get a road worthy Certificate , haven't done it my self tho [emoji28]
  • Like 1
Sad. They get pretty busy most days with engine rebuilds, mods and usual services. But pretty annoying they promised two days but took longer.
Being in similar environment, everyone wants to know when it will be ready
Go short and your a flaming mongrel if it blows out.
Go long and you miss out
Best guess is still only a guess
Right, Under promise, Over Deliver, retail 101.
I'm not upset that it's taking a bit longer, I'm disappointed because we discussed a time-frame, and they couldn't keep it, and they didn't ring me to tell me it was going to take longer.
Also, it took more than 24hours, just to apply tint to 1 window, I know they out-source the tint... but it doesn't take 24 hours to tint 1 window.
also, they charge by the hour, so the longer they take, the more I pay.
Ring around on places that tint c what the going rate is this way you know you wont be over charged, also you are paying for something to be done/service if you dont get said service then negotiate
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
