Why are limes so damn expesnive at the moment?
$10 p/kilo at the spudshed, or $1.20 each at coles (at about 100 grams each thats $12 p/kilo!)
What gives Perth?
I diy for my work / daily car but won't take risk for my 35 [emoji22] too complicated ! How did you go with fixing your door? Should we organise some fund raising car wash towards your door ?
I've been quoted $1000 to get it fixed which is going to take me about a month to get, mortgage and bills and what not. I'm not going to ask for donations or a fund-raiser for something like this, it's purely on me and my responsibility. That being said If anyone needs some odd jobs done or is willing to pay me to wash their cars I'd be delighted to... Or if some one would buy my subs/amp ahaha. Other than that the cars just benched until I can afford to fix it/change the tires.
Thanks for the thoughts though.
  • Like 1
What gives Perth?
buy a tree and keep in a pot. the dwarf ones at bunnings are around $20-30 and dont grow very big.
graft a lemon branch onto a lime and have both fruit from the same tree
speaking of fruit ive now got orange, lemonade, pink lady, granny smith, mulberry and 2 Nashi trees in the ground
want apricot, cherry and a dwarf avocado tree next
Canningvale markets on Sunday mornings have better/healthier and cheaper fruit trees than Bunnings IMO
Or even Marangaroo on Saturday mornings.
i went up to guildford garden centre who seems to specialise in dwarf fruit trees for some of them
  • Like 2
That's fine too =) Bunnings charges wayyyy too much for what you get. Just sayin
actually i shopped around a bit and i didnt think they were too bad,
i bought citrus from there and it was in good shape and $20 each for dwarfs
i only went to guildford cos they were the only ones who seem to do Nashi pears and their website shows stock levels which is handy
Hmmm.... maybe
Hmm interesting. I have been looking at the plants there for ages and always found them to be quite pricey. Maybe I haven't been looking at fruit ones for awhile. Or the Bunnings near me is just shit with their quality of plants. Good to know about Guildford though, might take a look if they have anything I want hehe
https://www.bunnings.com.au/200mm-sublime-lime-tree_p3661591
$28 for a lime tree, if I kept it alive it would pay off.
How hard is it to graft a lemon branch on?
yeah fruit wise they are well priced and both bunnings in bunno they are in good shape. local nurseries dont do dwarfs
not sure how they compare with trees
ive never tried but heard its easy
not sure when best time to do it is either
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
