12 hours ago, PranK said:
Yeah I have a feeling the app config/data might be cached. I'll get to that but we have a nice new responsive front end which works perfectly on mobile so they can use that in the interim. Thanks for letting me know.
Response from Christian about you guys having problems with the app not working
  • Like 1
4 minutes ago, z00key said:
awesome thanks for that, as for 26 is that a RB your talking about?
Would anyone say this is a good deal or not worth it?
http://www.gumtree.com.au/s-ad/kewdale/engine-engine-parts-transmission/rb25-turbo-set-up/1117376932
Gallo 24 :D:D
Yeah rb, needs work but got it at a good price
Z00key what power range do you wanna end up at?
Being a g2 it might not hit 400@wheels. But would be responsive.
Not a bad price if in good condition. Send the link to "hypergear" and ask his opinion and price to do an "update"
He is good to deal with ;)
  • Like 1
400 is kinda my want figure as it is my daily but just under is ok.
Back in the day they were made g1-g4
G1 was virtually standard and g4 did 430@wheels but laggy.
G2 and 3 were best IMO but I never looked at g2 personally.
I've "upgraded" mine once and only paid for shipping. He offered me another upgrade too but I refused. Now that's awesome service really.
He will have best knowledge of that exact model
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
