1 minute ago, t_revz said:
Lolz
What's the plan?
Well after buying the RX-8 I had $2 in the bank account before payday. Just paid rent and everything will be a little sad for the next fortnight I reckon haha
  • Like 1
Tell me more about your RX-8 , missing out all the previous conversations :( how much you pay for it and mileage ? Year ? Dave had one before and sold it and now he's looking another one - typical Impulsive men
Awesome. Didn't think it could be started at airport. About $80 from airport to tokyo so I'd prob get a pass then Elle
Ok Trev , I'll get the rail pass before we go there . Thank You [emoji317]
2004-ish? 120,000 kms-ish?
https://www.ceruleantower-hotel.com/en/
We stayed here in Shibuya, it was amazing, has a gym but they charge decently to use it, food and service was 5 star
Disney resort looks really good, was about 30mins? out of tokyo by train, super autobacs 2 stops down
  • Like 2
Thanks Corey :) Heard about popular Shibuya area , and had a lil look and did little research about it. Don't mind the 30 mins on the train :) and I can use the same rail pass to go there ? One rail pass for all ?
You have to watch, the rail pass we used was for Japan Rail, one of the lines you had to switch to a different company but the ticket was only 300yen or so each
Pretty sure disney was all japan rail
  • Like 1
Japan rail seems big and popular for everything ? Trev gave me the link to get a rail pass , I'll have a look on Saturday , plan and map out. [emoji3] Thanks Corey , so much to learn about Japan
Elle.  For parts just use Amayama, you will have to know the part numbers though it will end up much cheaper then get a workshop of your choice to do the work, downside can be parts warranty may not be covered if the workshop is not supplying it, so for things like brackets, hangers well amayama is the go, it's all a gamble but given the price difference, then the time spending yourself ordering parts.
Genuine vs Non genuine - I always prefer genuine as you know it's been tested on the car and made the way it was made to be, with aftermarket it's hit and miss you really need to see peoples experiences with aftermarket pads and rotors.  Brakes are one thing I would not cheap out on.
Unfortunately we get GTR Tax.   Genuine rotors for R33 GTR for example are like $1800 or something like that.
Aftermarket is good but chose known tried and tested brands, I'd go for something like a street pad as it will be more kinder to you.
But Elle forget all that, I want to see you tune that beast and raise the boost.
Edited by RB335
  • Like 2
Thanks For the advise Boris :) I've asked Josh from Galvsport to suss it out for me [emoji13]
10 hours ago, ElleAli76 said:
When are you going to Canada ?
Won't be until next years christmas holidays i reckon. Wifey wants to start trying for kids pretty soon so that will slow things down
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
