19 minutes ago, turboedsloth said:
Morning people. Yay for monday. As of Saturday we are booked out for the rest of the year :bunny:
Time to bump that hourly rate up mate ;)
  • Like 1
14 hours ago, turboedsloth said:
It's already at $121. Time to look for another body
That's better than it was, sounds pretty fair.
Glad you're doing well mate.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
