7 minutes ago, ElleAli76 said:
I'll see what they want to do, Are you coming ?
Don't think I have any Saturday plans, if the missuz tells me I haven't already committed to something I may tag along.
  • Like 2
Cool Just Let us know If you can , So that we can pick You up [emoji28]
  • Like 1
6 minutes ago, ElleAli76 said:
You're not the first girl to offer me that ;) rawr
  • Like 2
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
