Issue I had with adoption agencies is that I never had a pet before and so they weren't too keen on giving me one.
HRWA are not like that, they just want to ensure you know what you are getting into, Huskys are a unique breed and are extremely active
Malamutes are just huskies on steroids.  all my animals are sleeping because they live happy relaxing lifestyles. my dog gets two 8km walks a day.
Oh, and yeah, adopt one. there's so many out there.
Edited by Manne
  • Like 1
Yea ok I'll have a look. House doesn't have an alfresco area. Ideally I'm hoping to get that up at least for work out door shade area for the dog.
Have a chat with Anne, as long as you know what your getting into you will be fine, they charge $400 for costs of desexing, microchips and worming etc
http://www.huskyrescue.com.au
Tell her I sent you 0413 770 092
  • Like 1
I don't have a very large house, in fact it is quite small. To make up for this, I take my dog for long walks and play with him at the park, which is perfectly fine. We'll play tug of war in the yard and sometimes we wrestle, he's 55kg...decent opponent.
  • Like 1
No wonder your knees are shot 16km per day plus walking around at work [emoji15][emoji15]
  • Like 1
35 minutes ago, shoey85 said:
No wonder your knees are shot 16km per day plus walking around at work emoji15.pngemoji15.png
So about that, I have some sort of Chondral Fissuring of both knees. Essentially, the Cartilage for both knees has deep cracks and fissures through it, some of it has also started peeling off of the bone, and there a small, loose bits of cartilage floating around the knee too.
Theres no surgical options, supposedly (Rheumatologist tells me that, so does my GP and Physio), so the best Cure is to Grind back the Cartilage with low-impact leg exercises.
I had to buy a particular Exercise bike, that has a heavy flywheel (7kg), set the resistance up, so it's like pushing a weight, a slowly do that for 30 minutes a day. This not only builds muscle, but grinds back all my broken cartilage, and hopefully creates a new groove for my knee caps to sit in. Unfortunately it's a long, slow, painful process, slowly improving every week.
Option B is to take Anti inflammatory pills for the rest of my life, with monthly (expensive) Steroid Injections and fillers (with the risk of infection from each one).
Fux man that's really not good, hope
You do get better sooner rather than later!
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
