Specs:
Mobo - Asus ROG Rampage IV Black
CPU - 2011 i7 4930 - @ 4.6
GPU's - 2 x GTX 1080 Hydro Copper
Ram - G.Skill Ripjaw 16gb (4x4) @ 2400
Case: Phanteks Enthoo Primo
Water Cooling :
EK Supremacy Gold CPU Water Block, GPU's stock WB's - Classy HC's
Rads:
1 x EK 480 x 60mm Rad for GPU's - 8 120mm fans Push Pull
1 x EK 240 x 60mm Rad - CPU - 4 120mm Push Pull
2 x D5 Vario Pumps with EK X-Top pump tops
NZXT External touch screen Fan Controller
Hard Drives:
2 x 1TB Samsung Evo840 SSD in raid 0 for OS and games
256GB SSD for Downloads
600gb Velociraptor for general data
PSU - Corsair AX1200i
OS: Windows 10 64 bit
BitFenix Alchemy blue LED lighting 600mm x 3 and 1 white 600mm
Monitor - Asus ROG Swift PG348Q
ASTRO A40 Headset
Logitech G700s Mouse
Logitech G19s
Old pic from when I first built it update pic next week [emoji12]
Mine has Metallica stickers on the case so I guess I win
  • Like 2
Does look nice but when I play online I like an equal playing field [emoji8]
Can play online against xbone with forza now [emoji106]?
I use a controller for forza it just seems to work better than kb mouse
  • Like 1
Theatre room coming along nicely.
Screen is up, front 3 speakers done, now rear speakers then knock a hole in the ceiling for the projector. Hopefully wire most of it up tonight for a test
  • Like 3
Who are you with?
SGIO they wanted 2k for renewal but after dealing and changing a few things around i think i got a good deal as they are premium insurance. Was thinking goingbudget direct as they wanted $850 but the things they dont cover wow.
Plus i got 65% NCB n 3 other policy with them if i pull out the other 3 go up lol
Who are you with?
Personally I don't like SGIO. They decrease agreed value so much from year to year it's not worth it. I found Justcar and Shannons so much better albeit being more ex. Shannons now dropped their prices quite a bit for ex Justcar customers.
But if it SGIO works for you it's great, can't fault their pricing.
  • Like 1
Yea precisely why I didn't go with them. They actually called me up saying they will give me 20% off first year. So I asked what's my agreed value in year 2, isit guaranteed to stay? They said nope it'll drop but can't say by how much. Two weeks later they called me back with a much lower value cause the calendar year passed. Lol no thanks.
JustCar and Shannons have never dropped my cars value. So yeah staying with them for now. Paying $1,200 for $28.8k for my v36.
A combination of SGIO and RAC, because Motorcycle insurance is expensive.
Yeah for the import I don't think there's anywhere else to go but SGIO, Shannons, JustCar or now apparently AAMI (taking some of Justcar clients, not sure if it's open to public).
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
