55 minutes ago, ElleAli76 said:
That's fine Justin :) If I can't wait then I'll
Just pop in to Apple Store , don't think
You guys do 512 gb apple
Laptop emoji335.png, saw the 256gb only I think
If it's not on our website probably not, but I won't know until im next at work.
  • Like 1
1 minute ago, colin.ssc said:
If you want, try Freeway Smash Repairs in Osborne Park. They do really good work. They fixed my car up v well, good paint job too..let me know and I'll let him know to expect you?
Not today, the air-con in my skyline doesn't work and I used 1/4 of a tank going to mandurah and back.
The guy told me i'd have to get a new front skirt (at my cost) and then $600 to paint and fit it, as he won't repair the existing.
Then he wanted $450 to pop the dent under my drivers side mirror, and another $600 to respray the door to match.
Then he wanted $1000 to remove the rear skirt, pop the dent, fiberglass the tear and then respray and fit, or $600 if I supplied him with a new rear bumper, and he would just paint and fit.
You can see the dent on the side in the photo attached, have no photos of the rear at the moment.
Yeah, after he went inside, I looked at my friend and said "You're kidding me right?" and he thought it was a good deal.
In other news, I've been quoted a maximum of $500 to fix my Air-Con, roughly $200 + whatever a fan for an R33 would cost (depending on the issue)
Edited by Manne
Ok, booked the Skyline, and my Lancer in for some Paintless Dent Removal, should be fun.
I spoke to three different places and decided to go with Dent Dismissal, as he seemed to be the most knowledgeable after a small discussion over the phone. There was a guy called The Dent Man, who was $50-$100 cheaper, but he basically just said "shouldn't be a problem, will come up good", where as Dent Dismissal gave me more information, "Based on the location, sharpness of the dent i'll have to do X and Y, could take a little longer depending on how it comes up, I've not worked on that car before so I don't know how long it'll take blah blah".
Will let you all know how it goes.
Edited by Manne
  • Like 2
Mother in laws passport should be ready any day. We spent the money we had put aside on the house. Getting a bit of overtime lately so it's still possible but my wife said on the weekend she would like to go for New Years instead so I'm not sure what will happen
  • Like 1
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
