Don't worry you pretty lil head , give me date when and the address :) I'll
Do the LOT cost you nothing oh , check On my Facebook page NCCS and just to let you know my work is guaranteed [emoji12]
Do the LOT cost you nothing oh , check On my Facebook page NCCS and just to let you know my work is guaranteed emoji12.png
Is that actually you?
7 minutes ago, ElleAli76 said:
Yes Hank ! My company called NCCS -Nooks and crannies cleaning services duh!
Well shit! I had no idea!
In that case I won't use anyone else, screw those losers!
I'll send you a FB msg
  • Like 2
Oh also , just received a good news from the agent - my shop / showroom or chemicals supplies warehouse will be starting operating in one month time ! IMG_1487051880.374872.jpg
The owner of the shop now have accepted my offer :) NCCS is expanding and will sent the invitation out to you guys soon
  • Like 3
lol what do you think I do for living? Selling drugs ? Lol [emoji23]
  • Like 2
Awwww thank you :) just let me know when and I'll try to fit you in :) The girls will be happy with some extra job :) email or text is fine
0425611000
Elle
  • Like 2
Wow first time i used uber today so i booked uberx and uberblack came for the same price coz all uberx was out...
wow wee audi A8 brandspanker came n got me cost me 23$ to airport.
while if i got a commowhore or a falcoon taxi would of been 35 at least.
Very happy.
  • Like 3
https://itun.es/au/QHJuab?i=1079131934
Bit of riri hey Elle [emoji6]
Lol [emoji28]
Work, work, work, work, work, work
He say me have to
Work, work, work, work, work, work!
He see me do me
Dirt, dirt, dirt, dirt, dirt, dirt!
So me put in
When you all gon'?
Learn, learn, learn, learn, learn
Me no care if him
Hurt, hurt, hurt, hurt, hurting
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
