Liquid limestone. Just finished prepping 2nd area. Quick bite to eat and I'll fire the mixer up default_wink.png
I have 3 kids and didn't get sleep in at all [emoji23]
12 hours ago, t_revz said:
What's the difference between x and black? Car price? How many levels are there?
There's UberX (normal), Uber-maxi whatever for large group and UberBlack which is swanky af.
Everytime you go up a level you pay more.
From what i know uberx is $1 per km while black (top class) is $2per km now there is one more in between its people carriers.
Also i did get charged a uberblack flagfall of $2 and 18min in car was $5.60.
  • Like 1
How much should I charge if I use my GTR [emoji38]
Went to work straight into nightshift did not sleep at home or plane was up for 22hrs. Went to sleep i can't sleep now after i woke up from 3.5hrs of sleep [emoji27] [emoji22]
Huh ? Too much sleeps ?
Im using my PC, don't notice a new layout.
Did some things to my car today, found out some new troubles with my car today as well.
Got some Quotes.
Back to saving $$$$.
Time to move it on b4 you overcapitalise
  • Like 1
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
