8-10 on what?
New stereo was about 1100
New Michelin PS3 245/40ZR18 all round
Wheel alignment, parts
12/8/16
Nistune, tune and alarm system install at C-red
19/8/16
New Spitfire coils and power tune at C-red
New front discs ordered DBA T3
Braided brake lines
Tein coilovers
New replacement coil harness
Cooling pro stealth intercooler and piping
124000 - 30/7/16
Coolant flush and replace with Red
Oil and Filter flush and replace
Transmission oil flush and replace (Partial sump only)
And a whole bunch of little shit
  • Like 1
Not sure mate just having a look at what's out there, not keen on a certain 400hp with stock turbo r33
Considering checking out modifications for the 34 tbh east bear kit and a paint job/body work and some nice wheels then up to 300hp work from C-Red & drop a manual in it, just need to weigh it all up
Manual conversion 3k maybe lil more with better clutch
New computer 700 (nistune) - 3000 (haltech)
Injectors 500 -1000
So many turbos to choose from but go hypergear ATR43SS (its what im going to go and trev has) 1600 approx inc lines plus you can ad extras (bushings vs bearings)
Exhaust 500 -3000
Upgrade to more acurate guages 1000
@t_revz anything else you reckon?
Oh if u do go haltech you will want the dash to go with it.
Injectors 500 -1000
Exhaust 500 -3000
he has nistune already
injectors $1000
SS2 turbo is gooooood
exhaust $1000 for 3 inch straight though with 1 muffler and jjr bellmouth dump
fuel pump upgrade
and Nos....2 of the big ones!!!
your welcome to try mine to see what an SS2 feels llike before you buy
just watch out for Kerbs
  • Like 3
Just now, z00key said:
Yours bushings or bearings?
ball bearing. SS series 1,1.5,1.8,2 and 3 were all ball bearing.
atr43 series was bush bearing.
not sure about the new SAT series. i havent kept track of that topic for a bit
used to be around 900 for atr and 1600 for SS. about 400-500rpm difference in spool
  • Like 1
It has a 3" exhaust turbo back already but it's a Mank one from a dodgey shop so would replace when a new turbo is bolted up.
Needs new injectors, fuel pump, afm, turbo to make 300 ish
Spoke to Mark about E85 he said don't bother
3 minutes ago, shoey85 said:
I
yeah you wont need e85 for 300
i did 266 with hiflow turbo, intercooler and powerfc with a bit more boost. maxing out injectors and AFM
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
