42 minutes ago, ElleAli76 said:
This is Bloody good stuff ! Colin You should try it !
we go through one every couple weeks.
Japanese ricer is tastier and i dont need it but here ours is a bit bland and boring
  • Like 1
I'm sure they sprinkled this in my ramen or any Japanese foods that I had in Japan , I saw this in Asian groceries today , so I bought it and this is my first trial, had it with mashed potatoes, tuna steak , mushrooms and Wasabi Cheese lol [emoji23] IMG_5815.JPG
Surprisingly it taste so good [emoji39]
18 minutes ago, t_revz said:
You didn't like it?
Oh nah Motul is good, been using 300V for a few year. I just find that it turns black quite fast. I am changing as KYP recently become Moty's distributor in Australia. So I will be changing over to test it out. From what I have heard and read it's very good oil. Apparently in Japan when the cars at the endurance race used it and when they took the engine apart after the race for a rebuilt, those engines using Moty's didn't have scratches to the block or pistons etc. But as usual, I take reports with a grain of salt...what better way to just try it out lol.
  • Like 2
so I rung my insurance company, because now it's considered "theft"...the only problem is they want $200 MORE than what O'Briens are charging me to do it privately and I'd lose my no claim bonus...
Why the hell am I paying for insurance?
Have done on motorcycle only why's that ?
Just use windex [emoji23]
It's insurance until you call them up and realise it was only a assurance for your piece of mind. Then everything else will cost extra. Oh sorry we sold you $1000 bills worth of lies. (sorry)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
