SAU has been recovered after a catastrophic hard drive failure.
The latest viable database backup we had was from 6am yesterday which means we lost 6 - 7 hours worth of data before the crash. It was during the 12pm backup that the first crash occurred followed by a 2nd crash at around 3pm.
I am sincerely sorry about this and I hope that everybody didn't lose too much content.
Any questions, please PM me.
Christian
  • Like 2
1 hour ago, t_revz said:
Lachy, what's "ideal" camber and toe for my 33? In 16 years not one set of fronts has worn evenly. Even with 5 or so alignments in its life.
Think I need to tell them how I want it set.
Do you have adjustable front camber arms? If not your camber will be fixed.
Negative toe or 'toe out' increases inside edge wear so you'll want to steer away from that.
Positive toe or 'toe in' increases outside edge wear so if you run that with negative camber it will help to even the tyre wear out.
On your car where you want it to handle well and have reasonable tyre wear something like -1.5 degrees front camber and 1-1.5mm of toe in either side (2-3mm total) might be agood place to start?
Tis all stock brah,
Thinking bout getting tires swapped across and get it checked/adjusted. Something is obviously not quite right
Just now, t_revz said:
Tis all stock brah,
Be interesting to see what your camber readings are like.
have had it 140,000k so id say ive put 5 sets on the front. everytime ive hit canvas on the inside before outside has hit 50%
rears have worn evenly everytime.
1 minute ago, z00key said:
If you are running coilovers and a bit lower that could be where the uneven is maybe?
double check the post you quoted...
Tis all stock Brah. As if spend money on suspension when more engine powah awaits :)
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
