7 hours ago, Shoey84 said:
1490238094023.jpeg this ones stuffed
have you got a short shifter?
do your tweeters have a lip so they can be mounted through the door?
is that a shift light off the A-pillar?
whats sitting on the vent near the A-pillar?
Yep its a short shifter.
Umm not sure about the tweeters will have to have a closer look.
Nar no shift light.
The vent is missing all together
4 hours ago, t_revz said:
very convenient
i smell a rat
I have "Small focus of medial facet retropatellar chondral fissuring and basal chrondral delamination" this is caused by the concrete floors at my work and the constant kneeling, squatting, climbing ladders etc... I'm essentially a cripple on a bad day.
Worst part about this is, I made a claim to my work about it, and ever since they've been doing EVERY THING in their power to try and fire me, each week they get closer and closer to it, I sneeze in the wrong direction and they investigate it. The Area manager told the Assistant Manager today "I won't stop until I get him!".  It's ridiculous and i'm not qualified to do anything else.
f**k man it's called unfair dismissal if they do that to you
f*cking p1gs stickered the R34 tonight while the wife was on her way home! Didn't like the lights and they think the engine leaks oil WTF!
Ah man that sucks. It's why I don't use my car often.
Geez he sounds like a top bloke. As long as it's been brought up before they can't say its caused by something they catch you doing in the future
it's not my managers fault, he's a decent fellow. But the 2IC and 3IC go behind his back straight to the Area Manager etc... it's work politics, it's bullshit and I'm sick and tired of it...
f**king shit dream boats, Should be able to get it off easily. FYI you will need to acquire a permit for the intercooler as a modification been done to the car.
There's a form online some where if i get a chance to look today I will send you a link.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
