Wtf how dare my phone change God to rajab. I find this deeply concerning?
There are a few words on the forum that auto change due to language or just for the lulz.
Such as tur-key becomes the sphincter of the universe
  • Like 3
Compression test shows
1=150
2=155
3=155
4=150
5=155
6=150
Intercooler is full of oil again, proberly about 2l worth lol.... catchcan and overflow bottle is oil but relativly empty. Guess its new turbo time, injectors and ecu time
1=150
2=155
3=155
4=150
5=155
6=150
That's good news. Thought it may have been a ringland as they are so common.
When I stripped mine at 180k it had 5 broken ringlands but only 1 was letting oil past
has any one got one laying around there not using. I would like to see if i can get my dash boost gauge working again. 58d5c9477d71d_boostsender.jpg.ea7764faf13d61475f1a005c6bfd09bb.jpg
Ahh so that what it is i was wondering why i hot a floppy tube and gauge not working. I still will be maxing it out tho [emoji12]
I suspected ringland failure amd it still mite be, but to have comps that high i think there ok. My motor got a work out Thursday night so i suspect that finishwd the turbo off. Original turbo from new on 176k, its done well
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
