24 minutes ago, pol1on1 said:
Ok no problem
Is your car the one from down rockingham way? There was a guy selling both his gtrs, one was silver and striped out with a cage, the other was silvwr with a 400r bodykit and -5s under the hood
  • Like 1
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size [emoji7] (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin [emoji24][emoji24]
Will know more after first inspection this week, wish me luck!!
  • Like 2
Morning all!!
You can borrow my rims if they suit, I'll be home Wednesday to discuss further.
  • Like 2
14 minutes ago, shoey85 said:
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size emoji7.png (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin emoji24.pngemoji24.png
If you're willing to do the legwork of removing them and putting them back on you can borrow my rims and guardliners. (R33 and R34 are interchangeable, my front left is an R34). Not sure if rims will pass as the front left is bent (only noticeable at high speeds)
  • Like 2
Morning all!!
Just rock up with my car , I'm sure you will
Pass with flying color ? lol kidding !
Wait service at Honda..... Feel like I'm in Japan again [emoji7]
  • Like 1
2 hours ago, shoey85 said:
Morning all!!
borrow mine just put some new rubber on it for me :P
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
