That looks awesome, only difference on mine is wouldnt need the maf. If you could give me a ball park figure (you can pm me, private message) or just post here as im sure[mention=143902]shoey85[/mention] and[mention=143051]manne[/mention] might also be keen?
It's like t-revs said I will have to have a look and measure the diameter and angles. Guessing or copying will not be the same on your car as mine is fully custom the maf will have too be accounted for and the pod filter and bracket might be different. More than happy to have a look and help you out for cost price on the bends and will weld it for zero. Nothing is as easy as it looks, it a skyline!
  • Like 2
Scared you'll be defected?
Spool noise with steel pipe is awesome!!
Already have 2-1/2" steel painted black no point changing the cooler is only 2-1/2" unless I upgrade the turbo which is miles away so nah all good.
2 minutes ago, t_revz said:
@manne
Whaddayareckon
Telstra and "Cheap" don't exactly go together, unfortunately.
I've sold phones for nearly a decade now and honestly don't believe in "one phone to rule them all".
Iphone 7's seem pretty decent,  but as always, sept/oct = new iphone.
Add $15 if you want "Stay Connected" which is Telstra protection package for the phone (Replacement phone if anything happens to yours).
https://www.telstra.com.au/mobile-phones/mobiles-on-a-plan/iphone/iphone-7
https://www.telstra.com.au/mobile-phones/mobiles-on-a-plan/iphone/iphone-7-plus
These are the current prices, Other thing to look into would be purchasing the phones Outright, and signing up on a BYO Phone plan.
https://www.telstra.com.au/mobile-phones/plans-and-rates#byo
The benefit of this is that it's much cheaper per month and if something bad were to happen to either phone, you can still upgrade it to a Mobile Phone Plan and get a new phone. The downside is paying upfront for a phone.
That's about all the information I can give you, the rest is you making a decision, and hopefully coming to see me so I can earn that $$ ;)
  • Like 2
I wish my breathers were that short
The mandrel bent bends on the intake are awesomeness. My setup and exhaust are Frankensteins in comparison. Mandrel bent bends chopped on angles and welded are not a substitute for something that's been proven and engineered.
  • Like 1
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
