51 minutes ago, t_revz said:
sounds the same as japan then,
i would get one here but i have NFI about what i want. id rather think it over or probably just do what @Manne recomends when i see him :)
Sadly I won't recommend you anything. I can't tell you what to buy, all I can do is give you prices and walk you through features.
i would get one here but i have NFI about what i want. id rather think it over or probably just do what [mention=143051]Manne[/mention] recomends when i see him [emoji4]
My mate Glen has a fully bombed hx with Nfi on the plates!
Hey team,
Anyone able to help me out, I'm looking to replace these 2 hoses in my Engine bay as one has a split in it, and the other is just the wrong hose and could kink easily.
The usual places (Supercheap etc..) haven't be able to help me. Any Advice?
Also, my Valve Cover Gaskets and Seals arrived today, will be changing them out next week probably.
  • Like 3
Hey team,
Is the blue silicone hose just crushed or is it tapered. Although I work for epe I got mine from ozlink in Oconner. 3/4 " I/d clear with a s/s wound inner to stop the collapse. I went there to get get some s/s and Ali fittings but the minimum eftpos was $20 bucks so I grabbed the hose aswell.
Hey team,
I have been going to make the cam breather hose out of 2xs/s 90* bends with a straight in the middle but I am lazy.
Hey team,
Check out the ozlink or epe website
Hey team,
The cam breather will look poxy with bent hose and not the 90* bends.
Can't remember and will have to check if it is 16mm I/d or 19mm I/d, (5/8") or (3/4). The bigger the I/d on the hose and fittings is better because the bigger it is it draws less vacuum.
DSC_0325.JPGYep it should be a 5/16" I'd hose. The one from ozlinc is obviously a clear one with a s/s winding. It looks bigger but is a 16mm or 5/8" I/d that has to go over the swagging. From memory it cost bugger all for a meter and you could do the cam breather in a loop for the time being to stop collapse?
DSC_0325.JPG.9b80a4a8ba5bae5c5cc911de150bbc76.JPGYep it should be a 5/16" I'd hose. The one from ozlinc is obviously a clear one with a s/s winding. It looks bigger but is a 16mm or 5/8" I/d that has to go over the swagging. From memory it cost bugger all for a meter and you could do the cam breather in a loop for the time being to stop collapse?
Zoom in on the pic and you will see the mm pretty accurately. Also mypoxy electrical tape split cam cover breather. Lol
Just now, Beyond Blue R33 said:
Nice and tidy engine bay dude. I like it.
Thanks for the help dude, you know your shit. :91_thumbsup:
The blue hose has kinked, it's not the correct hose, previous owner must've just slapped it on there.
I'll check out those websites and make a few calls on Monday.
  • Like 1
It's a skyline, show us your previous owner. He needs a good and solid kick in the nut bag! Mate I had Blue discs, coil packs with the top of spark plugs hacksawed off and shoved in for contact, a heat shrunk wiring loom for the coil packs. Garden hose and evian bottle catch can, a ton of wiring that dropped out the bottom of the dash, the wrong bushes in the castor arms because they were off a 34 and codged in, split boots all round, the seats weren't bolted in properly front and rear, it was that low and out of camber that it had torn chunks out of the tyres so I lifted I't on the tein basics to 100mm all round , the battery and hicas ecu were toasted, the roof lining had dropped, water pump and timing belts were codged up, s/s braided oil feed to the turbo leaked with broken studs to the manifold and turbo, dump pipe was spilt, the centre had split out of the poxy chineese exhaust, radiator was trash, the carbon fibre b/pillar covers fell off, duckwing rear spoiler came off, battery was out of a Nancy's car, gear box boots were split, stereo and speakers were f**ked and didn't work, it's been mental, but she's fully solid and pulling hard now. My mate Dave has 30 years experience as a mechanic for reference plus all the looking up and research off the forums. Well worth it. I've owned 4 different v8's a bombed escorted and a jag. Love the Nissan the best of all. Turbo power!
  • Like 1
Hey team,
I always try to avoid doing more work at work but dealing with those dickheads is ridiculous, super cheap, auto one, repco, auto barn, Bursons. I would like to help you but unfortunately I have no mechanical knowledge, qualifications or experience? Anything I've seen on here t-revs knows his stuff and could help you out better with knowledge advice and information.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
