Thanks for the help dude, you know your shit. :91_thumbsup:
The blue hose has kinked, it's not the correct hose, previous owner must've just slapped it on there.
I'll check out those websites and make a few calls on Monday.
How did you go with finding the s/s wound 5/8" hose today? I wouldn't mind seeing if I could get the original cam breather hose from Nissan also depending on price?
I didn't, I worked all day, won't have a chance to look into it until wednesday
  • Like 1
1 hour ago, Beyond Blue R33 said:
Hicas, attesa, gt-st, gt-r, gt-t, R32, R33, R34, R35, evo, wrx, Nsx, type-r, fc, fd, ae86, asashi, sake, sushi. I'm a bit limited with my Japanese. What about t-revs? Fresh from the land of the rising sun? No substitute for experience!
my wife is a japanese teacher who hasnt worked since having kids, but perth is too far away :(
  • Like 1
2 hours ago, Beyond Blue R33 said:
3 hours ago, t_revz said:
got none...
Ahh, bourbon/whisky, best cure for any cold or flu, till the alarm goes off at 5:30am the next day. Putting a lemon in the neck of the beer should help out alot also.
yes i agree.
im considering putting honey in a bourbon/coke :)
  • Like 1
After 3 months of squealing and telling myself they will bed in. I finally got off my cake hole and chamfered the new front pads. Only the p/s was squealing but I did both to be sure. I took it real easy on them to bed them in and aren't sure why the p/s did and the d/s didn't? Dba slotted rotors and bendix advance pads. Any ideas?
what process did you follow?
i have Q1RM pads. they said to do 2 runs from 60-0 as fast as possible. then 2 runs from 100-0 as fast as possible. i had just skimmed rotors too. never had any noise from them
  • Like 1
is wednesdays your day off?
i have mon-fri off next week. might come visit one day
Ill check out what we have at work tomorrow and see if we have anything like it and let you know. I went with the clear s/s wound so it wouldn't collapse and could see if it was leaving any oil residue or staining inside the tube after the s/s wool packed catch can. Before the air intake to the turbo. I've pushed the car pretty hard on occasions and have had no blow by. Yeay. My catch can is a fully poxy drift one. (from autobahn)
I bought it the day I picked up the car to get rid of the evian bottle and garden hose to avoid a yellow. So for the mean time I put another 5/8" fitting reversed inside the can and ran it to half way in the tank and and cut the internal s/s hose at 45* so it would filter fumes and still had room to dump oil. Will fab up a new one and plumb it in properly from Ali when I have the time. (NEVER) :-(
  • Like 1
I work:
Monday: 8:45am - 6:00pm
Tuesday: 7:45am - 5:00pm
Thursday: 1:00am - 9:00pm
Saturday: 8:45am - 5:00pm
Sunday: 11:00am - 5:00pm
That doesn't include mandatory morning meetings, and customers not getting the f**k out on time.
My roster very rarely changes, but just in case always double check.
Edited by Manne
  • Like 2
Put the whole lot in new then braked reasonably hard 80-20, 100-20. Only p/s squeal. I mainly chamfered the lead and trailing edge at about 30* with a fine cross cut metal file and just took the edges off very minimally. All good now. Just hate doing a job twice. F##* might not have stood on it hard enough.
Did u check if it was a 5/8" or 16mm fitting? Just put a rule on it like the pic I posted and check the pipe o/d (outside diameter) not the swage diameter. Let me know. I would assume it is but always check.
I was worried about the abs juddering on the new rotors and pads if I hit it too hard so was just a guess.
Try nissan. I've replaced with genuine before and don't remember getting raped
It might pay to put a tiny bit of permatex on the corners and rear. Especially if its leaked bad off the rear exhaust cam side before. This will cop a lot of heat because it is near the manifold, turbo and dump pipe. Just a thought. Check there is no gouges or issues around where the leak was and it seats and Seals nicely. Pay attention to the fit up and get everything hard finger tight first then cross torque the cam cover like you would a head gasket. Clean all of the sealing faces up tidy as with a turps rag and make sure there is no gritty bits hanging around or shit from the rag. Use a soft brush to clean up the inside of the cam covers if it's gritty. Set aside a load of time and don't rush it! Don't know how much mechanical experience you have so just general advice. Nothing worse than dumping the gas pedal to a oily smell. Will be awesomeness once you have finished!
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
