one more early morning then i finally get a sleep in.
gotta finish modifying my chimney so i can start lighting the fire... so bloody cold lately
Yeah I've got a old Jarrahdale wood fire too. I normally run a pedestal fan on it like a supercharger. Even when you close the valves it makes for a way better combustion chamber (hemispherical) and dissipates the heat round the whole house. The performance is amazing from a two valve heater. Surprised the cat hasn't caught on fire he's fully old and loves that sh#t.
ive got a double doored model in an enclosed brick chimney in the middle of the lounge room. ive put vents in at the ground and top to circulate over the fire and get the extra heat back that i lost last season up into the roof. last season we got none of the heat from the top or sides... it all escaped away.  ive already cut out the bricks, just need to finish the vents then plaster up.
A dogs leg in the chimney is also a good fix and helps the chimney hold heat especially in a two story. I'm a sheety by trade and what you've done sounds awesome. Check out TheBlackNobility Charles hotel on you tube. Last gig I ever played. The guitarist was insane and teaches at cosmic.
You've inspired me to get back on the Roland and have a crack. Through the 901's and subs of course!
1 hour ago, Beyond Blue R33 said:
Coolness I played drums in bands round Perth for 20 years. What guitars/amps do you have?
BC Rich Warlock - Afterburner
Peavey Amp - i forget the model but its nothing flash
2 hours ago, t_revz said:
need to walk around the house doing figure 8's to sort it out
any advice ideas for the diff? What bands have you played in?
sorry got no advice. Corey is the man you should talk too
never played in a band. just learnt a few riffs etc and i play Rocksmith sometimes too which is pretty fun
Cool like Kerry king from slayer. I've got a mega old pearl. DW pedals. Paiste 2002s and the old Frankenstein writing paiste sound formulas. The 2002s are the same as Bonham, moon and Ian paice from deep purple used to play. I've met Ian paice, Dave lombardo, zak Wilde, jojo Mayer, Dom famularo, Jimmy degrasso, sepultura, and what not I used to be pretty good and have a few signed drum heads at home.!!!
Cool like Kerry king from slayer used to play
  • Like 1
DSC_0351.JPGDSC_0352.JPGDSC_0353.JPGDSC_0354.JPGwas so lucky to meet Jeff hanneman before he died. He was totally drunk. Haha. I met cyco myco from suicidal tendencies as well. Haven't played in anger for about 5 years mainly due to being old and the knees. can't be assed dragging the kit around anymore anyway. That's mainly why I wanted to join Sau. Missing playing in the bands and wanted to talk to like minded people about the car. I'm no mechanic but love nuts and bolts!
4 hours ago, Beyond Blue R33 said:
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
Winding the coilovers up wont change the spring rate, there fix at the manufacturers spec. Further travel is made harder by more fliud transfer, now u have more fluid either side of the piston its harder for the piston to move.
Made ur diff has seen better days? Our cars arnt exactly spring chickens. Years of abuse and the diffs is saying "no i dont want to" lol or on the other side of the scale mabe its not been used hard enough so wasnt quite working as it should? My mates vn ss had a issue with the diff, wouldnt put any power down just spun one wheel. Changed the oil and took it for a sqirt around the block trying to get the diff to work and all of sudden it just did, locked up and holy crap it hauled ass. Been fine ever since and leaves 11's if used in anger
DSC_0351.JPG.7dc9fb5485cf94c8eac465942b1b0b8b.JPGDSC_0352.JPG.4a11989d0932ed0cff057b4f9c12fd05.JPGDSC_0353.JPG.e8ac078d64d94c697bfe745507386499.JPGDSC_0354.JPG.9218eaa87696055a3ecbe0cf62cf6136.JPGwas so lucky to meet Jeff hanneman before he died. He was totally drunk. Haha. I met cyco myco from suicidal tendencies as well. Haven't played in anger for about 5 years mainly due to being old and the knees. can't be assed dragging the kit around anymore anyway. That's mainly why I wanted to join Sau. Missing playing in the bands and wanted to talk to like minded people about the car. I'm no mechanic but love nuts and bolts!
The top drum head is a used one signed by Dave lombardo (slayer) The second I got signed from Ian paice (deep purple). The last one is from when sepultura toured in 99 the whole band. I scored the Ian paice for the father in-law and he had it hanging in the living room up till he died then was given back to me. Got another pair of sticks signed by will Calhoun (living colour)
Cool thanks for the advice. The rears were bald inside when I got it so no wonder it torched them both evenly. It performed well today on the street. The car is at 3000rpm at 110 in 5th which is pretty annoying so I would assume it has 4:1.1 never had any issues till I lifted I't and changed the tyres. By the way it behaves I'd assume it's a 1.5 way l.s.d. Alot of people reckon the Achilles atr sport 2 are slippery tyres so should spin both easily. I checked all the mounts and bushes when it was up on the hoist at my mates work about 3 months ago and they seemed all good? More crawling around on the back required! Should be easy to fit in around 11hr days at work. Building a silencer that has dual 6" inlets to a 10" outlet 30" diameter 96" long. Double laminate 3.2mm thick body. Back is sore, I am old. I did the diff oil ride height and tyres all at the same time so makes it a bit harder to trouble shoot when it was all good before?
DSC_0166.jpegnot your every day muffler!
    • I would like to add that at least in my car, the RPM gauge shows around 200RPM above of what I can see at nistune.
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
