Thanks.
I half expected it to fall. I needed 3 arms so something had to balance but it slipped and got me.
Nearly done, fire is installed but need to fit the last length of flue and seal up the gland on the roof
Would assume it's 0.7 s/s crimped and swaged. I put a 1/2 inch thick flange in the roof split it down the centre and mounted it off the rafters so the top section of the flue had a mounting base to support the weight off the gyprock then a lead flashing on the roof under the tiles externally and 1/2" needle felt glass to insulate the heat from the gyprock under the flange inside. What you've done sounds great with the ventilation around the base and sides. Animal d.i.y. Show us your massive manifold and n/a exhaust.
  • Like 1
Well im home.....
Ran a 14.4@161kmh. Car just lays over at the top end so people just drive round me. I get out the hole fast but they run me down. Damn stock ecu and turbo lol.
Staging lanes were rammed and people cueing out the lane gates, and didnt reli wanna wait a hour to get another run
  • Like 2
Well im home.....
At least you can lauch it! I was crap out the holeshot and had to run everyone down. There were bugger all cars there last week on skyline night so got 5 runs in. Would be a worry to cane it with a fully cold drive train. Xy gtho, charger 6 pack and monaros all ran 14.4 stock from the factory. Pretty good at under half the litres. Show us your Nissan! Well done mate!
Did u have to hit 5th gear? I was about 6500rpm in 4th over the line?
3 hours ago, t_revz said:
@Manne
@z00key
coming to perth friday Guise. prob get there around 11 xox
I won't be at work on Friday.
1 hour ago, Beyond Blue R33 said:
If you check out the rear muffler you want on the magnaflow website I can get you a price on the part number. From super cat converters in Wangara. Will have all the dimensions there. Easiest way would be to measure what you have find one that's similar and has a I/d inlet on it slot it and use a accuseal clamp. You would only have to relocate the rear hanger bracket then?
i'll take a look, but I really don't know shit about my exhaust.
i watched WM on youtube. there is 26 x 22minute episodes plus there is a movie
i enjoyed the series more than i expected. initial D was better but its still very good. the movie isnt bad from memory either
Started watching the Wangan. Ghost-z lol. Way better than foxtel or tele though!
  • Like 1
Cheers, i woulda went last week bit football is my only real form of exercise lol getting it going was easy, 2.0 to the 60ft. Its not slow by any means, jist that top end lay over.
The things i'd do for a 240z....
My mate Daniel had one about 20 yrs ago was a sweet ride 2.4 bored to 2.6 with side drafts. Black and original. He swapped it for a cbr and a few grand cash. He wishes he had a time machiene!
Is hank away or something?
Also, any brake rotors and pads recommendation? Looking at DBA T3 slotted for fronts and T2 slotted for rears or Dixcel SD/HS (but HS is so expensive).
Pads Project Mu Bspec to go with Dixcel or Red Stuff to go with DBAs
Thoughts?
I got
Alcon advantage extreme big brake kit front/rear
6 piston monobloc calipers 365x32mm 2 piece rotors
4 piston monobloc calipers 350x32mm 2 piece rotors paired Alcon Brake pads
makes 180 back to 60kmh faster than what u get up to with max boost.
Puts a smile on everyone when thay back to normal in a flash literary i reckon 2sec
Washed the car too not much dust but whatever was there easy to clean .
I remember thinking my car was so quick when it was stock.
  • Like 1
Agh scrap that, realised its raining tomorrow. I have to get this flue connected today before the rain.
Might come next week. I'll keep in touch
All good bruv. Jump on jb website to have a look at the dishwashers on there and can let u know prices and availability
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
