where is everyone? been so dead since Martin left...
i hope he didnt take you all to Cairns without me
I thought everyone left because of my horrid social media etiquette. Double posts and under researched and funded questions?
  • Like 1
ill hunt around tomorrow for a better deal. surely someone selling the thin 0.7mm stuff has it cheaper than that.
im also going to get the fire at its absolute max with heaps of small stuff and find out the absolute max temps im going to encounter so i know how much metal pipe i need before i can change to PVC.
Gumtree n facebook marketplace always a good deal if you dig around. [emoji4]
I'm back at work dealing with bullshiht kids behavior shit talk [emoji35] .
Apart from that im a bit devo about my clutch i think the previous owner sold it at the right time.
Coz i only did like 3 launch at 6-7k with min slip and it just sitting that tad higher still bites at 3/5 high [emoji37]
  • Like 1
With more double posts and lengthy paragraphs to explain what normal people could within a sentence. Noobilishious:-( the diary of Anne frank on Sau.
Coz i only did like 3 launch at 6-7k with min slip and it just sitting that tad higher still bites at 3/5 high emoji37.png
it might be nothing...
launch another 10-12 times and see how it goes :cool:
  • Like 1
Just now, pol1on1 said:
Its nonstop nonsense i thought if you dont reacted to it thay stop but this is a New level of bonehead.
i try my hardest to ignore it but i cant bite my tongue all the time.
My work has been busy so I'm happy with that. Been loads of setup and working out new machinery. Plus new office, shop floor, and computer work. Refuse to be involved in any botching, bitching and politicking. Do the very best you can in the shortest amount of time for the maximum amount of money. Have bmx with the kids twice a week and pool three days a week for toasted back. Another novelist's post for anyone that cares to read it!
  • Like 1
the 33 strut towers Without modifying the rear parcel shelf. I put some new rear alpine speakers in the back a few weeks ago and it was a hassle to remove just for speakers. Any thoughts.
Do you know where this bracket is from......
I found it in my box of stuff not fitted to car.
Got a feeling its coz of my adjustable coilovers
is that from the left side of the boot? you put the jack behind it and expands into it holding it firm?
this is how i roll at home except i dont get paid...i just save having to pay someone else
  • Like 1
Nah i dont think so but the jack is in there spaced out tight. Bit of a puzzle for me i wish could go to the mega meet and raid a few r33 to find the location of my stuff.
had the safety manager come out this morning saying that we hadnt done enough hazard reports for the year. the system has been down so until this week they couldnt track how many had been entered.
but on the same page showing how few were done for us... it also showed that he had done fark all too!  so many muppets!!
  • Like 2
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
