23 minutes ago, Beyond Blue R33 said:
Has anyone seen the rising Sunday event at barbagello on the 4th? Or been to one before?
Cars n Coffee is this sunday at Kwinana... are they both on the same day?
i went to the first Rising Sunday. heaps of cars got stickered. was a good day but
Clearly you just don't appreciate how rare the Hyundai getz gtr is. It's a 1/1 worldwide. Will be highly collectable in the future.
If your not into collectable cars and like the getz tuner scene then this beast is for you! images%20(1).jpg
Never seen a bad boy like this before? It matches my swimming clothes!car-modification-fail-turbo.jpg.4c1bea07c03e73c563efd30492134a4a.jpg
Hey Trev I was looking up lifter issues on Sau and it had your posts solving the issue?! (r&d maniac) I've noticed a slight rattle in the exhaust cam p/s on no.6. I disconnected the coil pack at rattle revs. 2800-3200 and the rattle went away, phew no piston slap or gudgeon pin issues etc. Was wondering the fix for this without bagging my mate dave out.? Doesn't affect the performance at all and I's only in the specific rev range with the H.t. Lead disconnected? I changed the oil on Saturday and it runs sweet except for the noisey lifter on 6? At those r p.m.?
Hey Trev I was looking up lifter issues on Sau and it had your posts solving the issue?! (r&d maniac) I've noticed a slight rattle in the exhaust cam p/s on no.6. I disconnected the coil pack at rattle revs. 2800-3200 and the rattle went away, phew no piston slap or gudgeon pin issues etc. Was wondering the fix for this without bagging my mate dave out.? Doesn't affect the performance at all and I's only in the specific low rev range with the H.t. Lead disconnected it disappeared. I changed the oil on Saturday and it runs sweet except for the noisey lifter on 6? At those r p.m.?
I ran it hard on Saturday morning early on the old oil and it was noticeable at idle. Only noticeable at the 2800-3200 after the oil change? Would assume it only needs a new lifter? or clean (doubt it) and gapping not valve stem seal honing etc? Any advice?
Can only pick up the rattle in 2nd gear under mild acceleration?
i stripped and cleaned my lifters when i rebuilt the engine because i had a rattle for over 100,000Kms.
ended up getting a different head and modified it and used the lifters that came from the new head. the rattle is still there but turned out to be an injector which doesnt affect performance so i havent replaced it yet but i might in the near future as im considering an injector upgrade to top feeds
  • Like 1
how loud is it?
not sure if you can use an oil flush to get the gunk out... they arent too bad to clean apart from having to get them out. there are also a couple different varieties on our engines. look the same externally but different sizing internally
  • Like 1
sorry too hard to guess without looking.
id imagine with more revs the oil pressure would prevent lifter noise so idle would be worse but thats purely an edumacated guess.
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
