Yeah did a oil change Saturday. Had done 7000 so will change at 5000 now religiously it disappeared at idle after the change and is only 2800-3200 on no6 under gentle acceleration in second? Rattle rattle - gone? No noise with 6 coil pack disconnected! Weird.
how loud is it?
not sure if you can use an oil flush to get the gunk out... they arent too bad to clean apart from having to get them out. there are also a couple different varieties on our engines. look the same externally but different sizing internally
Haven't pulled the cam cover but goes away with no 6 H.t. Disconnected? So I would assume a cam lifter follower issue? Seeing as its on the exhaust side?
Series 2 R33 engine.
may sound like a dumb idea when your so confident of where the noise is buuuuuuuuutttt.......
its not an exhaust leak at the back?
  • Like 2
1 hour ago, Beyond Blue R33 said:
Can only pick up the rattle in 2nd gear under mild acceleration?
U should have a lisren to my engine, rattles at idle (suspect the turbo may well be dying lol) about 3k its got a ting ting noise and at the top it sounds like a big ol straight six on heat ?
Wouldnt be lifter, weather u disconect the coil or not it the lifters gonna do its job. However, if u disconnect the coil and it goes away ur taking the combustion away from that cyclinder. So id be looking for a leaky manifold around nunber 6 or anything in general todo with number 6
  • Like 1
U should have a lisren to my engine, rattles at idle (suspect the turbo may well be dying lol) about 3k its got a ting ting noise and at the top it sounds like a big ol straight six on heat [emoji23]
Yeah i panicked at first thinking ouch turbo, bearings, piston slap, gudgeon pin, big end knock etc. but can fully pinpoint the sound to no6 rear exhaust cam cover at only that tiny rev range. Will sus it out better on the w/end? Might need a real mechanic! Would assume tig welding it won't help!
Will suss it out better Saturday. Thanks for the advice guys, I appreciate it. It will give me a better starting point for trouble shooting. Never owned or worked on a car with a turbo or the cam shaft/s in the right spot except the last 8 months. Show us your v8's. She's running absolutely trick except for that! My wife and jack recond the noise is in my head! What noise! (perhaps the loony bin would be a better fix?) done all the turbo/dump pipe studs gaskets etc. So will check the manifold.
when you drive something often enough you can hear noises before anyone else or before it becomes a problem
Spent 3 months of weekends when I got it fixing rattles blips blurts knocks and bumps! Only drive her on w/ends. The captain always goes down with his ship. Then emerges with less money and More power!
  • Like 1
I remember having issues with the escort (when I was 18) flushed and cleaned everything new radiator, heater core, plugs points gaskets leads jets etc. I was putting a new head gasket on when dad came out and wiggled the no.4 piston with his hand. Think I found your problem mate! Sell it now.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
