Also not been on in a while just getting settled at wk and getting house baby ready (cleaned from top to bottom) trev i had a look at the dishwashers the asko have not much in em but apparently i get paid well on em ;) and the other 1 was about 200 off or something like that
  • Like 1
Can cast iron be tig welded to cast aluminium now?
I thought you needed friction welding or some other impractical method to weld those two together [emoji14]
I didn't say it would be strong
  • Like 1
Also not been on in a while just getting settled at wk and getting house baby ready (cleaned from top to bottom) trev i had a look at the dishwashers the asko have not much in em but apparently i get paid well on em [emoji6] and the other 1 was about 200 off or something like that
Cheers mate, I'll ask the current dishwasher what's she wants to do/get
  • Like 2
Yeah hardox is wear plate it comes in different higher tensile strengths and is common for use in load bearing/abrasive applications. Loader buckets, mills etc. More R+D from the master! Did u stick weld it?
Yep that's a jib alright! Any pics of your handi work?
DSC_0377.JPGbeen working on this stuff the last few days. Catch can with stack dual 2 " inlets to 3" outlet. reducers 10" nom from manifolds with bellows up to dual 12" nom exhaust pipes, dual 10" aluminised air intakes and all the engine coolant tubes for a M.T.U. Or (mostly troubled unit.) power generation. The 2x12" exhaust pipes run to a dual side inlet silencer 4' diameter 18" outlet with stack mounted on a frame outside the engine room. Show us your diesel!
Its running around 420hp on 98 and 480hp on e85 but took out the e85 tune to make the 98 one cleaner ( no e85 in my area ) on gtss turbos with kelford 265 cams. Bit lacking in power, really need to be up in the 500hp for a gtr but cannot complain I spose :4_joy:. Has full haltech catalogue as well
is that from the left side of the boot? you put the jack behind it and expands into it holding it firm?
Hey Pal are you still going to coffee and cars. Dead keen to check out the beast? Boss from work is taking his caddie down aswell apparently?
  • Like 1
Can't really see a reason to weld the dissimilar metals together? That would be highly specialised. One is a aluminium based alloy, The other iron based. I've repaired a few cast Ali/iron heads for cars/drag cars before. Fully F/G clamped the head to a 2" thick cast iron milled table. Pre heated with the oxy gently/the entire head gradually. Grooved out the crack with Ali Burr on the die grinder, down to where you can't see where the crack started, welding well before where the crack started and finished using cast Ali rods and pure argon. Post heated the head gradually to a cool down. The heat transfer properties and molecular structure of the materials are pretty much a polar opposite. Alloys are loose softer and dance freely, high thermal expansion and contraction. Irons are tighter don't dance and have low thermal expansion and contraction. Alloy's s are a/c welding with tig for castings. Iron's Are d/c - welding with tig for castings. They both have a tendency to spit the filler material out if you weld it too hot, that's where the pre and post heating comes into it. I crank the hot start up a bit because you will create a weak point if you hang around to get the weld puddle pooling. Easy on Ali harder for lower amps on cast. Nature of the beast. The pre-post heat is more critical on the alloy than iron. Just a thought? Our new Kempi tig has a mix setting that combines Ac/dc current and has a synergic setting as well? Can't beat the old analouge Hobart welder so far as I'm concerned. Digital, high low high low, analouge higgghh lowww, higgghh, lowww. Makes for beautiful pulse welding! Alternatively you could mash a heap of bird shit into the corner and hope the flux and slag sticks it togetherB-) bronzing, brazing, solder, pop rivets, silicone. Nuts and bolts etc:-)
Yeh mate. I'll be there
Sent from my SM-G935F using SAU Community mobile app
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
