Fark that
We have our own restaurant now at the bell tower. Colin said we all get lifetime 1/2 price meals and free drinks :408_beers:
Menu looks pretty delicious and reasonably priced for skylines in the city? Ferris buleah and Carrie Bradshaw can't come. But I'm all for Samantha, Charlotte, Miranda and Mr big. They didn't crash their dad's Ferrari?
wow...how random haha
  • Like 2
Someone's been watching too many chick flix [emoji6]
  • Like 3
why is it apart?
Just tidying up a few things. Pulled the intercooler flushed and cleaned. Pulled all the pipe work and swaged all the piping. It had poxy welds on it for the hose clamps. went over the Ali welds and s/s welds on the boost and intake side re-welded and pressure tested because it was messy welding. The exhaust leak on the cat flanges was because the ceramic substrate had come loose and was rattling. (like you said for lifter rattle/check for exhaust leak) redone all the tubing got a new viscous coupling and fan coming (Nissan oem) because the fan had some cracking. all new clamps from work and get rid of the black silicone hoses and replace with all Blue silicone to match the engine bay. I had re-worked the tubes before but still had clashing issues but done properly now. New tomei shifter to replace gay sparco one and venom 100cell cat with 3" in/out and 5" metal substrate to replace the ceramic. I've put new coil packs in aswell and iridium plugs gapped to 0.8. Just done a oil change plus gearbox and diff oil l.s.d. Paste not long ago. Wouldn't mid a tune to see how it's running. Probably won't make much difference to power as is running pretty sweet.
General house keeping. My ideas about welding and mechanical fitting are obviously different to the previous owner's. No biggies.
Just a refit on some stuff that was pissing me off everytime I opened the hood. Got a Cusco rear brace on the way to match the front and will get rid of the poxy 12" sub taking up the boot space and replace with a piano hinge properly fitting to swing up and down for battery and amp spare wheel access etc. Etc.
Had the car off the road for a bit when I bought it and just tidied stuff up. Not a daily so will do stuff a bit better with some cash and time up my sleeve?
You know Trev R&D. Double door combustion engine:-)
Replaced the cords on 2 roller shutters on the w/end and have 3 new weather proof fluros coming for the patio and car port this w/end. Re done all my home tools last w/end and make up 3 new tool boxes one for mechanical one for electrical and one for marking and measuring. Been in the office at work so canning the weekends!
awesome sauce!!
fyi next time just get BCPR6ES or 7's instead of iridium plugs.. spend the spare cash on beer
  • Like 1
awesome sauce!!
Or bourbon or whiskey:-) I replaced all the valley cover bolts (it only had 2 in it) with 5mm s/s Allen heads with anti seize and s/s flat washers when I done the coil packs and tarted up the wiring so thought it would save me from pulling and checking it for a while.
I don't run the valley cover, then I can change plugs without removing pipe work.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
