Finally got to installing the CD player my sister got me for Christmas into the boat, and the fkn power cable is missing from the box FML
If i get up early and get stuck into it I'll have it finished by oh no cable. Wait for the shops to open. F### it.
Yeh pretty much. I'm building a shelving rack in the caravan now. Have to go into town at lunchtime for a pissup so I'll try get one then and wire it up tomorrow
  • Like 1
How did u go with the van shelves? Fitting the marine stereo after the piss up? Just like having sea legs? Nothing like a bit of swell in the garage on the trailer!
Ran her hard today at 18 psi, it loved the 200cell 4x6 metal substrate oval cat. Gained about 1" clearance though slotting the front mounting bracket and adjusting all the hangers to remove tension. All pipe work swaged re-re modified and redone with t-bolt clamps and beyond Blue silicone hoses. Genuine Nissan fan and dayco coupling. Pressed a slight flat into the exhaust to clear the rear sub frame and hicas delete. Houston were waiting for the next problem. You are the weekest link goodbye
Just got home so I'll wire up the stereo first thing in the morning
Only have this pic ATM with the new shelf not completed on the left. Also cut out shelves to go in the robe to convert it to a pantry cupboard. I'll update progress pics
  • Like 1
This place looks amazing. Great view too. Good work Collin.
Yummo! I cooked a beef brisket red wine pot roast for lunch. Every Sunday night the wife and I marinate some fillet steak sit down and watch a movie with cheese platter, meat platter, dips, antipasto, toasty bits and crackers.
  • Like 1
Coolness "how to customise stock stuff way better and faster" a novel by trevs.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
