Mouse hunt at Trevs shed.
Caught 3 and still at least 2 on the loose. Have found by putting music on loud they are oblivious to me being in there.
World's worst mouse catcher.DSC_0212.JPGIf you had pats on the loose in the shed he could round that s### up.
Anyone use Keverk crane on their LV or LT at work ?
Be dam careful with it i learnt the hard way yesterday
No but I've used Kevrek [emoji12]
Glad it wasn't worse mark. That could have done a heap more damage
Yes im glad too.
If it was the 1500 model maybe i would be worse off.
It did crush it and maxed out the motor and i could not pull my hand out lucky i could slip the lever between fingers and with the other hand pull the other way to boom up to release.
Lesson learned won't do that again haha [emoji12]
  • Like 1
Week days are very quiet (atmosphere will be abit meh)....which is quite sad but yeh, hope you enjoy the food =)
Fine with me more of a catch up with an old mate thought we would try out your new diggs in the process [emoji6]
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
