There isnt a whole lot of info on rb30dets in my desired relms of use. Most rb30dets area drag monsters...
Hmm suppose it's the difference between a punchy quicker less laggy spool or a wait for a bit and get the the the holly f##k on it scary spool. Response vs shear power balance. Loads of rb's you see with bigger turbo's tend not to be able to get off the line or blow up boxes half shafts and diffs. I'd say with the bigger turbo you would need a mental clutch and longer ratio to get the power happening or it would just snap stuff and light up the tyres permanently. Which is also fun:-)
6 minutes ago, TiTAN said:
High flows have been tried on an rb30 years ago. It was a cheap build basically stock Na bottom end with the 25 head and it came on like a light switch but come 5000 it hit a wall, by 5500 it had dropped about 100kw from memory.
This is no gd... mine will be a forged bottem end so looking to lean on it some ?
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".[emoji4]
Gtx3582r with an 50mm external gate is what i was also thinking. Either way i think external gates gonna be better
I had a pre gtx series 35r with 0.82 rear. If you tweaked the waste gate setup you could have 20psi at 3500. Traction was non existent below 100km/h, for Street use it was too laggy to be quick and too fast to be usable without potential jail time. You would start seeing positive boost (a few psi) at 2500 with a bit of load.
Guilt-toy had a similar setup and should be documented fairly well on sau.
This is my dyno sheet, 26 psi and the dip at 145 was spark breaking down, done on a 33c day.
13 minutes ago, Beyond Blue R33 said:
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".emoji4.png
I hear u can get cheap pipe? Gonna need some mikd steel and aluminium to make some pipe work. Proberly not till later in the year tho
  • Like 1
Hell yeah, that looks right up my street. I wont be using it much on the street, mabe once a week at this stage. Il proberly get hooked at drive it all tje time lol
thats a run out at an airport, i am not even an amateur film maker obviously as its hard to even read any of the gauges. had spark breaking down at 160 then it clears up and keeps going, trapped at 242km/h at the 800m mark.
  • Like 1
Sounds gd ?
16 minutes ago, TiTAN said:
That's mainly to give you an idea just how quickly 400kw puts on speed.
If it's going to be a track toy, you are going to need some serious brakes to deal with stopping it. Upgraded pads and rotors won't cut it.
350 all round. Alpha omega brembo upgrade. Dba discs and bendix pabs. With all my cars its always been suspension, tyres, brakes then power.
Posted some pics of the boot fit out. What do you think of it?
Looks good mate, should sound good too.
A lot of bass is lost through the back seat of our skylines due to the steel plate etc but will still be plenty of punch no doubt.
Is it all hooked up and running now?
  • Like 1
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
