Also got a photo of each spark plug
My opinion is plug photos are irrelevant except for checking last RPM.
ie- your plugs look richer on 3+4 but that could be just at idle.
I've pulled plugs after idling,cruising and on the highway turning engine off at 6k WOT and they look very different.
What plugs did you fit afterwards? Coppers or iridium?
Nah just did the comp n plug check
Yeah i do let it run a bit before i park up slow drive up the hill n cool down probably a good 2mins worth
Thay r PFR6A11 Laser Platinum Plug
Maybe 3, 4 could do a change coz of platinum worn a bit on edge but there not much KM on it.
Don't waste money on platinums.
Throw em in the bin
Sub 400hp I'd say bcpr6es coppers
Above 400 run 7's
Went to the city stage of the rally today. Way more skylines running in the mornings classic car section. Had some 32 33 34 gt-r and gt-st's Heaps better than the Malaga and Whiteman park stages. 5 hrs in very mild sun and strong wind. Curse of the ranga, unbelievably got burnt.
know them feels...
thinking of the sun gets me burnt
  • Like 1
On 8/12/2017 at 0:48 PM, pol1on1 said:
Yer i used deconjestion spray that solves bit of it but xray shows that i had a defomed canal that worked as a 1 way valve basically not allowing suction to top sinus (above eye) when landing which made alot of pain the worse I've is numb jaw striking pain down neck and numb collarbone with eye feeling like exploding that was every second swing landing for me.@manne I've read you have some similar issues
Yeah dude, Three weeks and i'm feeling much better but there is still a little bit of pressure around the nose/eyes that flares up from time to time.
I'm currently using a Sinus cleaner thing, it's a bottle with a thing you stuck up your nose and squeeze, and it flushes them all out.
Agree with you though, the Pain is UNREAL, I was knocked out for a good week, sleeping 20 hours a day, and then somehow, my chest became all messed up too.
Steroids, Sprays, Antibiotics and 3 and a half weeks, but i'm still not better.
know them feels...
Panicked when we got to Toodyay. Jack was like there is smoke coming out from under the bonnet. Wtf. Bonnet was a bit hot with no blanket underneath it was steaming the rain over the turbo off the top of the bonnet. Was just running up the hills in 5th and loading it up on the way there with the boost controller off. Used 4th for the hills on the way home at 14psi no probs. Different animal to the 4,9 5.8 5.0 and 5.4 lesson learned. Bugger all torque at low revs. think I will get rid of the 200cell catco oval and go to the venom 100cell with the 5" substrate. Tuning is beyond my nuts and bolts ability. Any thoughts? We ran sweet to and from Albany and did 1000kms pushing it hard. The original 100 cell metal cat copped a massive smash over a trainline bump at full speed the substrate came loose and flew into the exhaust melted and killed it and we popped a intercooler hose because it blocked the exhaust.(the weekest link) have swaged pressure tested and redone all the tubes and hoses with a intercooler flush. Would I need to retune between replacing the cats? Any advise would be appreciated. Thanks.
I will come Eli!
know them feels...
I will come Eli!
Don't get me wrong she's running and pulling hard at 18psi still. All temps and pressures are normal. Just seems to have lost a bit at say 6000 to 7000 under full load? Trevs? Kizza?
Hows weekend for Everyone ? Next week Saturday - Any idea where we going to meet up before head Down to barbagello ? Cruisinnnnnn All
Together from joondalup ?
Whos going ?
Yeah 84 and I will be there, my mate wants to come with so I'm gonna be in the Prado
    • Hey, guys, I鈥檓 hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It鈥檚 just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
