Yep have been doing a re-tooling. Feel guilty for the old sidcrome. Have had her for 25yrs, and was second hand then. Thought the kinchrome was pretty close to R33 gtr-lm spec championship blue.DSC_0290.JPG.2da6d7e527486b1461488b13ed0ee351.JPGDSC_0291.JPG.248a9ed41cfc8c91729f6b61c1a2269b.JPG
This a nice piece of kit
  • Like 1
2 hours ago, Beyond Blue R33 said:
Hope the tools work the same in a different box. Might loose their experience? All the drawers undone for reasonably rude replies? Kizza?
Cant beat getting into a nice pair of draws, remember if there matching... she decided not you!!!
Pullers, for that reli tight u know what..... and sometimes uv just gotta paste that bush, mabe by accident or mabe on purpose ?
My box, iv had it since 2006. Dani pedrosa in the top pic, nicky hayden bottom. Happened to be the same year hayden won the world title [emoji106]
Absolute beast for home. My bro would love the Moto gp action. All my good stuff is at work. Home only gets the retirements. It's a pain when I think I'll just get the? Oh it's in bibra lake. A quick 50 minute jaunt away:-(
The box is too gd to have at work, some asshole will only scratch it. I keep most of my gd stuff at home, just take the gd stuff i need in. Ideal for working on cars at home.
  • Like 1
1st 5 scratches / dents hurt anything after that Meh
Thats soo true leave a loose spanner around for 5mins n it gets flogged off.
My dream is to have a 1001pce tang toolbox at home and at work i find the 2nd hand shop ( deceased estate) not that bad as thay are old quality tools with rust on them dont feel bad if it breaks rusts scratched dents or go's walkabout [emoji4]
  • Like 2
The best hammers I have are from my pops shed and a heap I bought off a old English fellow at the markets who was also a sheety by trade. They don't leave dents in sheet metal. Nice flat faces. $5 bucks each and we talked tin bashing and the Beatles for a hour. Learned my trade from a old aussie fitter and Turner and a 60yr old English sheet metal worker. He used to make panels for old cars on a English wheel and sand bags with a wooden mallet. Could pull any solid geometry out of his brain but couldn't explain it much. He just knew what to do:-)
  • Like 1
Theres not many people like that any more
  • Like 1
I knew one in Brisbane and worked for him for a bit. It was great watching him shape panels and massage dents out
Dad is a electrical engineer and ended up doing computer programing converting all the gas turbine and power generation from analouge to digital to harness the information. Watched him build a boat out on the patio doing all the solid geometry 3rd angle projection [/img]and patterns bending and shaping the wood when I was a boy. He got me into the Nissan's when they were racing the hr31 gtsr and the gt-r took over in 1990.for Jim Richards to win the championship.Was all ford's up till then. Cams put 200kg on the 32 and limited them to 1.3bar when the coswoth Sierra was running 2.8bar. Nissan ran a huge motor sport program in the 80's early 90's in Australia. Exa series bluebirds George fury etc. Fred Gibson motor sport wanted to run in Japan at Fuji and Suzuka but Nissan said no.we do not want to be embarrassed. Rwd switch off the line so wouldn't snap half shafts. 1 4wd setting for dry and 1 setting for wet. The fastest gt-r s in the world from Australia. Skaife and Richards recond up to 700'hp on full boost.
  • Like 3
8 hours ago, Beyond Blue R33 said:
Dad is a electrical engineer and ended up doing computer programing converting all the gas turbine and power generation from analouge to digital to harness the information. Watched him build a boat out on the patio doing all the solid geometry 3rd angle projection imageproxy.php?img=&key=4b1e78680f916b86[/img]and patterns bending and shaping the wood when I was a boy. He got me into the Nissan's when they were racing the hr31 gtsr and the gt-r took over in 1990.for Jim Richards to win the championship.Was all ford's up till then. Cams put 200kg on the 32 and limited them to 1.3bar when the coswoth Sierra was running 2.8bar. Nissan ran a huge motor sport program in the 80's early 90's in Australia. Exa series bluebirds George fury etc. Fred Gibson motor sport wanted to run in Japan at Fuji and Suzuka but Nissan said no.we do not want to be embarrassed. Rwd switch off the line so wouldn't snap half shafts. 1 4wd setting for dry and 1 setting for wet. The fastest gt-r s in the world from Australia. Skaife and Richards recond up to 700'hp on full boost.
When the 1.3bar rule cam in nissan moved into multiple cylinder tuning.  Each cylinder had its own fuel and ignition trim. So when they had it all figured out they actualy made nore horsepower than they did befor lol and for the endurance races they knocked the boost back to 1bar. They could safley get 4000 racing kms out of there rb26 @ 800hp in the early 90s.....most of the time they ran in rwd only but in the wet they actualy configured it to run 60/40 front bias to gelp pull the car out of the corner instead of pushing it out.
P.s, ur dad sounds like a legend!
Edited by R33kizza
  • Like 1
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
