Pull the rail off and unplug the injectors without removing them from the rail and crank it, make sure it's not a bad o-ring.
Already done start of the year. Also had them cleaned. Tried winding Cas while spraying individually into a bottle and all spray pattern looked good. Replaced o-rings and refitted but still dilution.
Bought a wideband. Removed cold start enrichment and leaned out at cruise
Still dilution [emoji15]
Time to swap out injectors...
  • Like 1
What size injectors and fuel pump?
Blitzed spring onion, mushroom, white onion red onion and garlic. Caramelised and Reduced with red wine, browned lamb rump chunks, made custom gravy 2 1/2 hours in slow cooker. Fresh sesame seed crunch bakery rolls and creamy garlic mash on the side. Full dilution :-) deliciousness!
  • Like 1
Tasted like insane beef Wellington in a roll.
Aids?
  • Like 1
My missus made some tasty pulled pork rolls earlier in the week
Was dinner,breakfast, lunch and dinner [emoji4]
Yummo. 4 porks in 24hrs. My back couldn't handle it. Bummer about the unburned fuel past the rings. Would say maybe too rich or too aggressive timing. Too much duration on cams? Poor spray pattern etc. Worst case scenario hone or rebore. Compression test? Only a few thoughts. You know from a sheety. Have you tried pop rivets, tig welding or nuts and bolts. That's where my experience runs out so only a thought. it's just a thought. If my life is for rent.and I don't learn to buy. Do I deserve nothing more than I get. For nothing I have is truly mine. (Dido)
Aids?
Anything to do with beef pork or lamb and you're in:-) I've been recording the secret meat eats guy off sbs. Just smashed his beef Wellington recipe into the slow cooker with some modifications!
  • Like 1
New engine
Def not running rich
Cams are mild
One of the injectors is ticking so most likely that's the culprit but I don't wanna upgrade to top feeds unless I'm sure.
  • Like 1
I'm having issues with the sthil fs38 idle at the moment then bogs down under power so??? Tuning a Nissan??? Apparently I can't tune a 2 stroke whipper-snipper properly.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
