legs are NOT parking brakes
https://zippy.gfycat.com/SilverTerrificHarrierhawk.webm
My leg is worth more than that bubble bus! If it was the Nissan I would had thrown myself under the front bumper!
BCFn fun. Just took me 1 1/2 hours to get home. Truck crash roe hwy. Squidding with my mouth would be more fun.
Just grab my ankles and pony tail then launch me at that sob. Better than drowning under my own profanities in the e.p.e. ute.
Squid success.
Now time to eat [emoji4]
I made a dragons breath sauce on Saturday night. 2 x Red chilli seeds in,1 x scud chilli, 1 x habenero (optional). 1 x big chalott, 1 x bit of lemon grass (fine) 1 x big clove of garlic. big rough cut of coriander pounded in mortar and pestle with sea salt, fish sauce and soy sauce to taste, 1 lime cut in half and squeezed. Scary deliciousness.
Marinated 3 x 1 1/4" thick porterhouse Friday night. 3 x oyster sauce, 2 x soy sauce, 1 x sea salt, 1 x palm sugar, 1/2 cup of Port, 1 clove of garlic (fine) Marinated for 24hrs cooked medium rare 1 1/2 minutes 4 x per side in griddle pan, turning opposites for nice cross hatch pattern. Was eyeing off everyone's steak after I finished but no chance. Restaurant quality at home!
Reset reel mower to 0.1 gap with feeler guage, cutting perfect. Quad cut all laws back. Pruned all trees and palms. Trimmed air fuel ratio on 2 stroke whipper-snipper, fixed replaced and tuned all sprinklers off the bore, weeded all the gardens front and back. Played new uncharted on ps4, watched F1 at spa. Took jack out for 4hrs driving on L's. Back too work for a break:-)
1 hour ago, TiTAN said:
You need to find one like Finnegan from roadkill, the entire downstairs section is garage/workshop and then the living part is upstairs
Mrs wouldnt lile that, shes a picky bitch. I never did understand why she chose me ?
  • Like 3
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
