Gazebo. Or as I like to call it the white elephant. Wife had too have it. Brand new, never been used, no joy riders low ballers or time wasters. DSC_0315.JPG.5f92282c373ab30fb15b9cd82cbc2e93.JPGDSC_0317.JPG.72825973a1ab5f50dd25fac81a0bf604.JPGDSC_0316.JPG.be990c31d3136a28471933744a36c515.JPGchews more oil than a ls1:-o
Dad reconds if there is a earthquake or cyclone head out to the gazebo or patio. Totally over engineered.
  • Like 1
The cubby I built for the kids at our last house could hold a herd of elephants [emoji208]
  • Like 3
Will how convenient. Wondered if i may ask a favour if anyone knows and could help. My front lounge is open living and we would like to put doors on the 2 entries/exits anyone know how i would go about doing this? Would it be a hard jod to do or be able 2 give me a hand to do it?
A full herd of white elephant ridiculousness, the sheer irony is that the gazebo replaced the kids old cubby house. 90x90 timbers fully concreted and solid braced floor. Pine paneled door, windows, eaves out on to a small patio. Stud frame and full weather board inside and out. Full corrugated green roof to match the house. I slept in it a few times while drinking beers and listening to the radio in raging bad weather to sheerly justify the amount of work and expenses. Kids never used it! Fully funny to hear a similar experience. I lost my s##t. Again!
20170901_181439.thumb.jpg.784d04faeeb0f9bfbc71bd8c4b540738.jpg20170901_181431.thumb.jpg.86c5e61a41cf45adf8fa6509fb4298cf.jpg
The doors you get at bunnings/masters etc. Are generally only a generic size. You would need to put a architrave in (metal or wood) the metal architraves generally have the hinges built into the frame work. The first pic looks like a bigger width than normal. The second pic looks pretty standard. From memory doors are normally. 715mm small 815mm large. Could be 720, 820. Then once the architrave is in you just plane them down to suit because the doors have thicker wood on the outside the internal frame. You also have to fit the door handles and cut out the locking mechanism into the architrave.
I prefer working with metals, fuxk it up and u can weld a bit on. Cant do that with wood lol
  • Like 2
These 2 doorways am wanting to put doors on
Buying generic pre hung doors is easiest. As you don't have to work out the hinges etc. You can probably get them with hardware pre installed too at a bit of an extra cost.
put the door and frame into the opening and then make a bit of frame work around them to join them solidly with the edges of the opening/roof/floor. Leave yourself a small margin around the door for spacers to align the door. cover the frame work in plaster board, go for gold with the joint compound and spread it reasonably wide (~10cm wide over the join and don't be afraid to do a bit of sanding, then go for the finer top coat at ~20cm wide and sand again, it makes it harder to see there is a bump. Going too narrow makes the bump more visually obvious).
you may need to take some plaster board off around the edges of the existing openings to remove any plastic/metal reinforcement pieces on the corners for a better finish.
The most important thing is to take your time getting the door in the correct spot before you screw it in properly (square/straight) so the door stays where you open it to instead of naturally wanting to swing open/closed.
If you want pocket doors then that's a whole world of hurt to retrofit, just pay a pro to do those.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
