Nah you don’t have a bent front end or require parts
I'll find out the time frame later when I see him .
Anyone knows where in perth have ready stock for titanium tip exhaust ? I don't care if it's the whole lot of just the tip -'preferred HKS nothing over the top - same like you martin my money doesn't grow from the tree !
  • Like 1
Just jap online order and get it fitted later?
  • Like 1
34 minutes ago, shoey85 said:
Morning Krew! How are we all?
I'm alright, lost both auctions this morning.
More cars coming up on the 18th, may need to increase my max bid :(
  • Like 1
21 minutes ago, ElleAli76 said:
Where's dean ? @Zookey?
Everything is fine as far as I know, his baby is due in 2 weeks? so i'm assuming baby prepping is eating up all of his time.
@shoey85 @ElleAli76
Edited by Manne
  • Like 2
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
