Just now, R33kizza said:
Im married, my wife knows its the best way of getting me to do shit, specially shit i hate doing lol
im a workaholic at home...
my wife schedules "family days" so i stop doing jobs around the house
  • Like 1
If i havent got all the bits fir the job it doesnt get done, i hate getting motivated then only being able to do half a job....
im the same but ive got a million jobs to do so there is always something to do.
when i go to bunnings im usually buying bits for 3-4 projects at a time
ahh ill be working that weekend [emoji20]
Used to love the 4wd show at Macallum Park during the apprenticeship. 3 days out of the workshop doing f/all helping the big boss. Then 3 weeks worth of bearded men insisting that's not where we were or what we were doing and suggesting different ways upon how I earned my money. Rally Australia was worse. I was a Niaev handsome young man with red hair. Apparently.
Think of all the money you could have made on the side selling yourself after hours.
  • Like 1
$8.36 per hr. Flat rate. No overtime. Ouch
That's where you went wrong, think how many rub and tugs you would have to get done to not even make $9.
You charge based on the service you are providing with provisions for time limits. Clearly you were taken advantage of and you aren't a member of scarlet alliance.
  • Like 1
11 hours ago, t_revz said:
If i hadnt been busy with Owens appointments i would have gone for a look, mostly to see the caravan accessory stuff though.
You old kent.
  • Like 1
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
