Good luck finding a 6 speed man [emoji17] hard enough with the 5
:-o, just a thought. I get cheesed off with mine spinning through 1st and 2nd then 115kmph is 3000rpm. Brrrrr. Stereo loudness running block.B-)
Our cars don’t really have the balls at 110 to be running at low rpm.
I get ok fuel enonomy at high rpm and still can hit enough boost to get moving without downshifting
  • Like 2
3 hours ago, shoey85 said:
Can diff gears be changed?
Yep, a lot of 4.1 and 4.3s around. i just found a set of 3.7s on japan auctions ive got coming. Will be a good match for the 6 speed
  • Like 2
13 hours ago, Beyond Blue R33 said:
14 hours ago, shoey85 said:
Good luck finding a 6 speed man emoji17.png hard enough with the 5
Skyline life!! Get a new ecu and have boost by gear, 10psi first, 14psi 2nd, all of it there after
  • Like 1
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
